Thread: help!!!!
    Regular Member costalot's Avatar
    shropshire
    Default help!!!!
    My siggy has done 65000 and running abit lumpy, so I checked how 2 and it seems the EGR and a BOOSTER thingy mat need cleaning before they break omg .
    The jobs seem easysh, batted breath so I am going to have a look tomorrow if I get in deep poo is there anyone online tomorrow for help
    WGAF#5
    evening mate - theres generally a minimum of 20-50 people online during the day = so if push comes to shove .... hopefully you can get some online assistance
    shropshire
    Cheers pal I am stressing slightly over it but the stealers will want a bomb just to look and will want to put new parts in omg.
    WGAF#5
    no worries - good luck with the overhaul
    preston
    be confident
    follow the how to's
    get plenty carb cleaner
    at least 2 cans to start with
    and gloves to stop your hands turning black
    watch out for gaskets dropping off egr
    i reuse mine
    should run much better once done
    i'd also change air / fuel /oil filters + clean MAF ( with pure alcohol ) as a matter of course.
    cheeers
    Sep 2010
    Hartlepool
    I have just cleaned the throttle body, EGR valve and boost pressure sensor for the first time in my Vectra 1.9 CDTi 150 and I can truthfully say that if you read the HOW2's, make sure you have the right tools and any replacement gaskets (You need new gaskets for the EGR valve and the throttle body but they're only around £3 each from the dealers), just take your time and be careful and you will find it quite easy.
    I must add that a lot of people gave me good pointers on what to do so, if you get stuck or you're not sure, get back on here and ask someone.
