Thread: CD70 Unusual fault?
    Aug 2010
    Wolverhampton
    Default CD70 Unusual fault?
    I recently changed the CD70 on my car as the old sat nav stopped working. As the "new" head unit wasn't divorced from the screen I had to have it unblocked. When I fitted it I had A BOING noise every 5 seconds and a display safe notice came up occasionly. I took it to have it Tech2d and although it accepted my security code the noise wouldn't stop, so we gave it up as a bad job. I drove home with the noise and parked up. An hour later I went out in the car and the noise had stopped. Great I thought but later on today I discovered that every other time I drive the car the noise returns. Stopping the engine and the starting it doesn't work, I have to drive a short distance to get the silent result. Has anyone any Idea what could be wrong?
    Thanks in advance
    Mac
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    IT means 1 of 2 things..
    1: bad job of resetting it
    2: bad job of paring it
    Most likely the last..
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    have you got the bluetooth handsfree kit built into the car?
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    What you did with the old cd70 navi ? You need it ?
    CristianTM.
    Aug 2010
    Wolverhampton
    Hi, If it's the pairing why would it work some times and not others?
    It has a built in mobile but I do not now if it is bluetooth.
    I have sold the old one on ebay.
    Mac
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    You should divorce the radio and display before selling. Now you need to: use tech2, reset cid with carpass, reset cd70 with the code of cd70, the pair them together.
    CD70 without code can be reset somewhere in a radio shop, that's a very very easy job, So it's your cid that needs to reset.
  1. Unusual fault codes
    By m8internet in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2012, 17:45
  2. cd70 fault
    By pumpbay in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2011, 12:36
  3. Cd70 Navi Cd Fault
    By toughmat in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2011, 22:28
  4. CD70 navi fault
    By mky82 in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2011, 22:15
  5. Cd70 nav scroll wheel fault
    By Fearns in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2009, 23:10
