Thread: Rattling noise over 2800rpm (CDTI 120)
    Regular Member rec's Avatar
    Jan 2010
    Bradford
    Default Rattling noise over 2800rpm (CDTI 120)
    Hi Guys
    my CDTI has suddenly developed an odd rattle when you rev it over 3000rpm.
    i had a search on here and found this thread:
    http://www.vectra-c.com/forum/showth...=cdti+rattling
    not sure if its the same thing, or even how to check it.
    its kind of like a ratatatata noise when revved, it does it wether driving or sat still, but you cant hear it on idle.
    anybody got any suggestions as to what it could be?
    there are no warning lights on, and other than the noise the car is driving perfectly. want to get it sorted asap as the car is advertised in the Autotrader at the moment.
    many thanks
    Regular Member wright879's Avatar
    Chippenham
    Trim : Life
    Engine : CDTI 120
    One of my drive belt pullies made a noise a bit like that when it went but was cheap to fix
    Good luck
    Steve
    Jan 2010
    Bradford
    Quote Originally Posted by wright879 View Post
    Good luck
    Steve
    hi bud, anyway i can check it myself? or is it a garage job?
    thanks
    Chippenham
    Trim : Life
    Engine : CDTI 120
    Well you could stick your ear near it I suppose, or remove the belt to see if the noise stops?
    Once my duff pulley was off the car it didn't make any noise - only when under load from the belt
    Steve
    Jan 2010
    Bradford
    Steve
    dont suppose youve got a pic of what i should be looking at have you bud?
    cheers
    Chippenham
    Trim : Life
    Engine : CDTI 120
    No sorry I didn't take any pics but there is probably a how too on here somewhere
    Steve
    Regular Member rioni's Avatar
    london
    hey i had same problem , the problem is with time belt, a tooths are not properly in dot's go to mechanics and check the tooth's with AUTODATA. this gonna cure the problem cheeers.
  1. V6 CDTi pulse/surge at 2800rpm
    By Celes in forum Engine & Drivetrain
    Last Post: 19th July 2010, 13:38
  2. Signum CDTi-150 rattling noise
    By mr-s in forum Engine & Drivetrain
    Last Post: 7th June 2010, 09:59
  3. rattling noise
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 18th January 2009, 02:37
  4. Rattling Noise
    By rhodod in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2008, 18:21
  5. rattling noise
    By signumboy in forum Engine & Drivetrain
    Last Post: 6th February 2008, 20:28
