Thread: engine mounts
    Aug 2010
    herts
    Question engine mounts
    where are all the engine mounts on my vectra c 2.0 t and what are the common ones to go first as when i let the clutch out i can fell the engine clonk/jump and when changing gear to. thanks.
    Aug 2010
    herts
    anyone please!!!!
    Aug 2010
    herts
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    there are two on the sides of the engine mate and two or three underneath.
    The top mounts you can't miss, one is by the side of the airbox near the belts, the other looks thye same and funnily enough is on on the other side of the engine. The mounts underneath, if they are actually called that are more gearbox mounts, one at the front and one at the back, check these to see if the bolt has come out, mine had but a relplacement from the dealer is dead cheap..
    Somebody may have more precise info or pics for you later on.
    HTH
    Aug 2010
    herts
    thanks mate,, anyone got the part numbers for all theses mounts thanks.
    Aug 2010
    Leeds
    You may have a exhaust hanger broken and this maybe clonking.
    What is the year and mileage of this car?
    Jun 2009
    South Coast
    if you type in 'vectra c mount' into ebay you will see what they look like etc. both top and bottom mounts are listed but am not sure if the ones for you engine (Z20NET) will be available.. but you will at least know what you are looking for etc
    Like Bigtee says though, check other parts like that first though
    Aug 2010
    herts
    cheers nige, its on a 53 plate 46,000 2.0 sxi t.
    Aug 2010
    Leeds
    Quote Originally Posted by leesri View Post
    I very much doubt there faulty more like a exhaust bracket is corroded and hanging down and the box will knock when you let the clutch up.
    Have a good look at the mountings first.
    north east
    If it is a mount the most likely is the front gearbox mount a shocking design.
  1. Engine Mounts...
    By spoons in forum Engine & Drivetrain
    Last Post: 15th September 2011, 18:25
  2. 3.2 engine mounts
    By hankthetrucker in forum Engine & Drivetrain
    Last Post: 14th July 2011, 22:04
  3. Engine mounts
    By chrisvectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2011, 18:05
  4. Engine Mounts??
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 29th March 2009, 00:24
