Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: home electrical help
    Regular Member coylo5's Avatar
    May 2007
    n.ireland
    Default home electrical help
    Wiring help for a bathroom/extractor fan pull cord switch
    my old unit broke so i bought a 6amp 2 way switch of ebay it has L1-L2-COM- EARTH. the old one was ancient couldn't really see what was written on it but it had an indicator light on it which the new one hasn't. i have 2 red wires 1 black and 1 green/yellow coming from the bathroom ceiling. its not connected to my bathroom light its wired separate. ive wired it up but no joy i would be forever grateful if anyone can help me.
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Hi
    You need to connect the 2 reds into common
    Connect black to L1
    The switch is a 2 way unit hence the 3 connections
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    First question would be how was it wired up before you removed the old switch? Ie where did the reds and the black go? The green / yellow is the earth.
    Does the black have a red band round it?
    May 2007
    n.ireland
    Quote Originally Posted by Ste View Post
    they were wired into 3 different holes , the black is just plain black.
    May 2007
    n.ireland
    Quote Originally Posted by keefy*2010 View Post
    Hi
    Connect black to L1
    with the old reds going into different holes would this have been for the indicator light? i'll give your tip a go
    Jul 2010
    If the red wires were in different terminals
    then it would be wired as 2 way switch??
    Is there another switch in the circuit ??
    Normally
    The reds are the loop in and out I.e. one red is coming
    from another light the other red is going to another light
    May 2007
    n.ireland
    tried the 2 reds into COM black to L1 nowt happened
    there is a fuse box right between the fan and the pull cord if that helps?
    May 2007
    n.ireland
    Dunstable
    It's difficult to answer your question online mate without seeing the installation, if I were you I'd get an electrician to do it for you, not to be messed around with if you're not sure what you're doing
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    why are you messin with a black wire there is no nuetral in a light or a bathroom fan
  1. egr blanked - 2000 miles and no limp home home
    By jonestown in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 14:55
  2. electrical
    By lee324uk in forum Engine & Drivetrain
    Last Post: 1st December 2008, 09:34
  3. Replies: 71
    Last Post: 30th April 2008, 12:38
  4. ah! home sweet home!
    By pogo in forum General Chat
    Last Post: 20th October 2007, 21:03
  5. home sweet home aarrrrggg i love it !!!!
    By big phil in forum Introduce yourself.
    Last Post: 9th June 2005, 08:04
