Results 1 to 10 of 21
Thread: XP2/VXR Manual Gear Stick
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Default XP2/VXR Manual Gear Stick
    Can you fit them to any Veccy with a 6 speed manual gearbox?
    I take it the whole gear stick/column have to be removed?
    Gazza4
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It will fit yours mate, fairly easy job to swap the sticks too
    Sodding Typical on Sea
    Yip, It is one thing firmly on my list it is a replacement of the whole shaft and top.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Derek Mc View Post
    Cheers guys, btw I was looking at these ones - I probably won't buy it but would I need anything else?
    http://cgi.ebay.co.uk/ASTRA-MK5-H-VX...item43a2564c59
    http://cgi.ebay.co.uk/VAUXHALL-ASTRA...item3a5f4490ab
    Gazza4
    Blantyre
    Should take 20 mins mate, i have various posts advising people how to, hardest part is popping out the bottom ball joint and then putting it back in again to the new one
    You dont use all the black plastics as yours are fine, you just pop the big centre pin out you can see in the pic and use your own , if your close to me i can help you, i have done a few
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by spennny View Post
    Should take 20 mins mate, i have various posts advising people how to, hardest part ispoping out the bottom ball joint and then putting it back in again to the new one
    Cheers spenny m8 will have a look.
    Gazza4
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    You'll need a gearknob for the second one (thats just the insert)
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Thought the genuine Vauxhall link one was too cheap.
    Gazza4
    Blantyre
    If you stumble across an XP2 insert drop me a PM
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cheers bud, will keep an eye out or it may be a visit to the dealer worst case scenario.
    Gazza4
  1. Gear stick
    By tubby in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 03:04
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
  4. Help with gear stick
    By wayne10244 in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 21:04
