Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: car finally died today
    middlesbrough
    Default car finally died today
    Well my vectra finally decided to die on me today , after plenty of mouth to mouth and cpr via jump leads she just gave up and decided to play dead. ~So it was put on a wagon and taken to the dealers
    been having problems with her for weeks now, 3 diagnostic machines all showing no code errors, 6 mechanics all scratching their heads and no one knows whats wrong , had a few good ideas from the boys and girls on here all checked and all came back ok .
    will let you all know what vauxhall say . . . . . . . feels weird not having a car though
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    What engine?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    When you kept restarting it - how frequently did you try it - every 1-2seconds?
    Gazza4
    Sep 2010
    Hartlepool
    Gazza4 - He's having the same problems as I was having.
    Throttle body re-solder should fix it IMO.
    Worked for me
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by RichyA View Post
    Worked for me
    I know m8 he is but restarting the engine within every 1-2seconds when the plate shuts (that's the result of the fault) keeps the vacuum in the inlet manifold which effectively causes the plate to 'seal' off the manifold - making restarting the engine impossible. It also gives the impression the car is dead, but if you hold of for about for 10seconds then restart is will in all likely hood start no problem as the vacuum has disappeared by this time.
    Gazza4
    Sep 2010
    Hartlepool
    OK. He lives near me so, if it is a fix on the throttle body and he needs a hand, we'll arrange a time and I'll drop by to help.
    middlesbrough
    Gazza , we tried starting every few seconds, then minutes then held the ignition on for a good few minutes all it did was just keep trying to start , eventually battery died sowe put jump leads on . Its in vauxhall now so just gonna wait and see what they say .
    Richie , pm sent , thanks for advice and if vaux say needs new throttle body then I will try solder first.
    This car will not beat me , I will not let it
    middlesbrough
    What engine?
    its an 05 1.9cdti auto 150
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I say that as it could be the throttle plate has jammed shut and may be giving the impression the car is dead. The real operation of this valve is to control emissions (EGR flow) and limit the 'shake' effect when you switch off the engine.
    As my understanding has it - under normal driving it will vary it's pitch when in part load and under full load it opens up (WOT). When you switch the engine off the valve closes momentarily, then opens again. The valve is spring loaded in the 'open' position (Normally Open Valve) and needs electrical current you close. This electrical current is controlled via signals from the ECU - which is using data from MAP, MAF and pedal positions sensors - to control the EGR flow into the manifold. One of the other signals it will recieve is one in which the engine is switched off, when the power to the TB is cut, there is a signal to close over the valve, hance when this signal disappears the valve opens up again.
    The EGR valve as I believe in the CDTI's is either fully closed or fully opened - and hence requires the throttle plate to change the pressure difference in the manifold. Opening the valve increases inlet manifold pressure which reduces the pressure difference between the two manifolds. closing it reduces manifold pressure and increases the pressure difference between the two manifolds. The CDTI has a two EGR valve so has no position sensors within it, however the ECU uses the MAF sensor to detect EGR flow. This means blanking the EGR valve will produce the management light still, as opening the EGR valve will cause a reduction in MAF readings which is what the ECU will look for under 2,000rpm.
    But I ain't 100% it's months of DD's posts, links and others on here which I have came to this conclusion.
    Sorry for the rambling and it is not fact just the conclusion I have come to.
    Gazza4
    Sep 2010
    Hartlepool
    I understand what you are saying with regard to the valve open and close position.
    When I removed the throttle body to clean and repair it, the valve was in the open position so I cleaned it and moved it to make sure it was moving freely.
  1. 2.2 Dti Died today need help !!
    By elongmoss in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 18:08
  2. car died today
    By baz_cdti_sri_150 in forum Engine & Drivetrain
    Last Post: 1st August 2010, 19:28
  3. Tiny died today!
    By NellyD in forum General Chat
    Last Post: 28th July 2008, 22:19
  4. What a **** today! Mushy and his Siggy nearly died!!!
    By mushy2007 in forum General Chat
    Last Post: 3rd April 2008, 21:13
  5. the real soulman died today
    By soulman in forum General Chat
    Last Post: 26th December 2006, 19:55
