Results 1 to 3 of 3
Thread: Suspension Warning Light... ON
    spoons
    Guest
    Default Suspension Warning Light... ON
    Courtenays were unable to turn off my IDS+2 suspension warning light yesterday (without needing my security code) despite using Tech2 to 'switch the IDS off'
    So I came home with the warning light still on the dash.
    They are trying to resolve the issue as I type this, but it may lead to extra cost if connectors are needed
    Does anyone know how to turn this warning light off using Tech2
    Steve
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    You'll need your security code to access the Instrument Cluster as you mentioned unfortunately. Once you've got it you can just change the variant to "Not Present"
    spoons
    Guest
    Quote Originally Posted by tramman View Post
    Thanks Tramman,
    Thats great
  1. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  2. warning light not going out
    By peterAC in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2010, 18:34
  3. Warning light?
    By norfolk in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2010, 23:33
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
