Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Help Needed!
    Apr 2009
    Neston
    Default Help Needed!
    Hi Guys... I'm hoping someone here will be able to help.
    I've been getting white smoke out of the back of the Signum (2.0T) and got a code for the lambda sensor which was changed. Smoke has got worse with loss of power so called out the AA who diagnosed a faulty turbo.
    Had this confirmed by a mechanic who said the oil seals had gone so got a new turbo fitted. Now when they have come to start it up the smoke is horrendous as in it engulfed the workshop and interior of the car.
    First thought was rings but had it compression tested and all cylinders came back within 10% of each other. Anyone know what the pressure should be as all I can seem to find is the compression ratio?
    Any other ideas guys? Oh.... no more codes showing up on the code reader either.
    HELP!
    Regular Member vectraturbocal's Avatar
    Aug 2010
    leeds
    ye it will smoke for a while mate theres still oil in your exhaust, mine smoked for a few days after turbo was done
    Apr 2009
    Neston
    Quote Originally Posted by vectraturbocal View Post
    Smoke is a lot worse than it was before I had the turbo done tho
    Apr 2009
    Neston
    Compression test results were
    1st test 120 130 135 135
    2nd test 140 130 133 133
    These figures seem about right?
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by stupottyuk View Post
    Which unit of measurement are you using? The minimum pressure should be 12.4 bar (or 180 PSI). More than 2 bar difference between any two cylinders indicates a fault.
    Apr 2009
    Neston
    PSI so all very low i'm guessing. Any ideas?
    S.E
    I'm no expert, but the obvious thing to look at if all 4 cylinders are low on pressure is the head gasket, rather than rings etc.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    White some is usually coolant being burned off in ther cylinders so if what Jezzy is saying is correct, then it sounds like the head or gasket has packed up? What are the oil and collant levels like?
    Gazza4
    Apr 2009
    Neston
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Coolant levels have been fine and oil consumption is smack on what Vauxhall say it should be 1L for every 1000 miles.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Next point - injectors?
    Gazza4
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
