Thread: Is there some sort of cure for a weeping turbo?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Is there some sort of cure for a weeping turbo?
    My turbo seems to have a slight oil drip. It's obvious it's just oil vapour that is accumulating but it's accumulating on the intake side meaning oily pipes, oily intercooler, and more annoyingly and oily inlet manifold (just great when the car deposits it's exhaust gasses in there )
    Fed up with the sludge and don't want to have to keep taking the inlet manifold off and soak it in diesel every year.
    Would using a thicker oil help or is the best bet a new turbo? (if it's gonna come to that I will probably just stick with removing the manifold every year )
    2.2dti by the way and I know how the systems all work, just want to know if anyone else has changed the turbo and the problems gone
    EVERYWHERE
    Oily film on intercooler and intake hoses is quite normal, even when the car is new!
    Consider using a thicker oil anyway if your car has some miles on it (70-80,000 plus).
    See also thread about 'oil catch can' to find out where other oil comes from.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Been thinking of using different oil tbh, The car has done 99k and is running 0w40 Mobil 1 Supersynth and although there is no blue smoke (not even a trace) and it doesn't use oil, it really is starting to sound rather tractory.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Right from looking at that thread half of the problem may be the turbo and the outher half oil vapour from the engine, gonna buy myself one of these catch tanks I think
    Jan 2006
    Dalriada
    Sounded that way the last time i heard it
    Would be a good idea to try the catchment tank first buddy
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Lol it's probably just because the weather is starting to turn again and I am noticing the noise
    Sodding Typical on Sea
    John,
    The only 100% solution on the catch can idea is sadly an expensive one as it is either the Mann Hummel Provent 100 or 200 or Racor CCV6000 both about £150 but both are a 100% removal of oil solution.
    Derek
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    TBH even a 50% removal would do me. Just fed up with the inlet clogging up so much
    Look at the alloy ones on the bay, try to get a 1 litre capacity fill it with brass wool and it will do a decent job. I planned to mount mine on the firewall near the fuel filter (fwiw)
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Aye those are the ones I was thinking about mate, take it they come with no internals then
  1. What is your hangover cure?
    By mattv6diesel in forum General Chat
    Last Post: 20th June 2013, 20:27
  2. Bad smell cure
    By alcutler in forum Bodywork & Interior
    Last Post: 30th October 2012, 18:28
  3. slight oil weeping !
    By ant.vectra in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2009, 19:33
  4. Anyone know a cure for
    By mc_orion in forum The 'Off Topic' room
    Last Post: 21st October 2008, 13:32
  5. Header Tank Cap Weeping slightly !!!
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2008, 21:31
weeping turbo
