Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: KW Variant 2 Inox Coilovers
    spoons
    Guest
    Default KW Variant 2 Inox Coilovers
    Some pics of todays trip to Courtenay Sport
    Fitted KW Variant 2 Inox Coilovers to the VXR
    Started out at 4am this morning to get there for 8am... took all day and left at 6pm... then 3 hour drive home...
    So I dont really know what I think yet... as I cant think....
    spoons
    Guest
    I've got to let them settle and do some more messing about to get the right ride height... but not for a few days...
    spoons
    Guest
    Initial drive home felt tight, no dip under heavy braking, flat round corners etc... nice
    Still got a little bit of vague steering, but I think the PowerFlex bushes will help with all that.
    John at Courtenay liked it when he test drove the car
    Jan 2006
    Dalriada
    That looks sweet Steve
    spoons
    Guest
    Just had a very long (and productive) conversation with http://www.centergravity.co.uk/index.cfm
    Regarding the suspension settings with the Vectra VXR.
    He explained they have 3 main services to offer
    - Height Setup which takes around 60 to 90 minutes (charges £60 +VAT per hour)
    - Corner Weighting which takes around 60 to 90 minutes (charges £60 +VAT per hour)
    - Geometry (Camber, Toes, Caster etc) £199 +VAT one off fee
    They go through a survey of your driving style and environment to help set up the car perfectly... so its safe, stable, balanced
    __________________
    spoons
    Guest
    In my case he strongly recommended I allow the car to settle to the ride height I want over 1000 miles (long timeline) to 5000 miles (short time line) as my car is garaged for long time periods and low miles
    He suggested I maintain the ride height as 20mm lower than standard manufacturer settings on back, and 30mm lower on front.
    Any lower and it starts to change the pivot point of the car and could make it handle worse (more body roll through corners)
    However, he then suggested I get the Poly bushes fitted as soon as possible as the old bushes will now be 'twisted; in their mountings due to the change of position and will accellerate their failure.
    So thats the plan....
    - Set ride height
    - Get poly bushes fitted
    - Get corner weighting and geo setup
    Done
    Sep 2010
    Hartlepool
    Looks great mate. Did he mention anything about your bonnet vents?
    spoons
    Guest
    Interesting point he mentioned was to use the drivers door sill as the 'rake' level point if measuring in degrees
    spoons
    Guest
    Quote Originally Posted by RichyA View Post
    Yes he did actually.
    John had a good look at them and gave me the thumbs up. He said they are well positioned and should work nicely... also look really good.
    He also gave me a good idea to protect the ABS module from water using a plastic flap which I will add to the 'OMG VXRS' bonnet vents thread.
    So thats good.
    Sep 2010
    Hartlepool
    I think all the stuff you plan on doing to your car is going to have the same effect as coating the tyres in glue
  1. Another variant of 2.0 turbo..
    By Steven in forum Petrol Engine related
    Last Post: 28th April 2012, 00:35
  2. Coilovers
    By V6 Turbo Elite in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2011, 14:29
  3. Coilovers
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 22:28
  4. coilovers
    By magpie in forum Handling & Braking
    Last Post: 31st October 2010, 11:15
  5. KW Variant + Vectra VXR = WIN!
    By Netstar in forum Handling & Braking
    Last Post: 10th September 2010, 16:00
