Thread: Horn constantly going off and Raido control
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Horn constantly going off and Raido control
    So - posting this for chrisvectra as he is at work.... He has a problem:
    Driving to work the horn started to go off. When he got to work, removed the keys and it was still going off to disconnected the battery.
    So - he has checked the steering wheel wiring etc, and has found that if he disconnects the right steering wheel control (volume scrolly) the horn would stop going off.. But the horn will then not work at all even when pressing the horn.
    Before he disconnected the right steering wheel control - the stereo will skip CD tracks and raido will automatically change stations (so the buttons on the control are doing there own thing!)
    I think it sounds like that right hand steering control is shorting / failing somehow causing the horn to activate, and adjust the stereo etc..
    With this disconnected the Stereo is fine - just no horn at all (but that may be normal)
    Thoughts??
    Cheers Ant
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    no one got any ideas
    Middlesex
    Trim : SRI
    Mileage : 100k
    .... so bit of an update:
    Chris came to me last night and we did some work / testing / and in the end sorted (we think) the problem.
    So - the issue was that with the volume steering wheel control connected to the loom, and the two earth spades connected to the Metal horn plate (the full metal plate behind the airbag), as soon as you connected the volume steering control the horn activated... AND this happened when the horn plate was awar from the wheel.
    So - what we did to fix it was connected one of the two earth spades from the volume control to the big horn metal plate and the other to the black horn plate behind the big metal plate..
    This resolved the issue and the horn works, as well as the Radio volume control..
    What would be very hand please is for someone who has a facelift wheel, can you explain where the two earth points are connected two on your wheel to see what is the actual correct way...
    Are you VXR Enough
    13 Post(s)
    pics please pretty please
  1. Air con hissing constantly after re-gas
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 13:22
  2. Heater constantly hot. Help?
    By Critch in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 11:28
  3. Heater constantly blowing hot!!!!!
    By axelf in forum Engine & Drivetrain
    Last Post: 29th March 2011, 16:44
  4. Internal Fan / Heater Constantly on !
    By avitohyes in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2009, 21:36
  5. Radiator fan is constantly on, anyone help?
    By fuzzbomUK in forum Engine & Drivetrain
    Last Post: 29th November 2008, 18:46
vectra horn on constantly
