Results 1 to 10 of 13
Thread: cdti egr cleaning
    Regular Member mrk's Avatar
    14:88 our time will come
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default cdti egr cleaning
    as above, i remember someone posting a good guide to totally stripping the egr but i can't find it
    anyone thanks
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    http://www.vectra-c.com/forum/showth...clean+egr+cdti
    i couldn't see it either, but i had this link saved,
    Trim : improving
    Year : 06
    absolute epic service, thanks v.much m8
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Pay particular attention to the area pointed with yellow arrow!, clean this 'shroud' whilst working the spring, also ''don't'' put grease into the elec solenoid end!!, use wd40 or a light thin oil, or elec contact spray.
    http://www.vectra-c.com/forum/showthread.php?t=105853
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by the-wizard View Post
    I had mine off last time and the whole valve/plunger moved fine, but I still get the 'flat' spot and slight hesitation at 2,000rpm? Is this possibly a burnt out solenoid? Though logically I can't see how burnt out solenoid could cause hesitation problems as the solenoid is used for opening, a spring returns the valve to the closed position - like I say though the whole setup moves freely - plunger and solenoid.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    There seems so many hessitation/flat spot problems at the mo it could be any number of things, egr, 3rd inj wiring,tb problems,boost/map sensor, just to name a few ?. Just as a point ive had my 04 rg from new! I also have had this problem, 100% of the time it was a direct problem with the egr, cleaning this 'like a new pin' has always solved it, Im now at nearly 65k with the original EGR.
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    TB plate isn't a problem now. , boost sensor was cleaned last week. All injector wires/plugs have been replaced, and I'm going to change the vacuum hoses this week although they do look perfect for a 122k deisel that has never had them changed.
    Gazza4
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I would change them along with checking everything else!, I once had a ''very small'' carbon ball stuck in the egr and it played hell when driving, where are you located ?.
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    West of Scotland m8
    Thinking about getting a newer updated one. The one I have is a reconditioned one (has the 3mm hole drilled in the solenoid).
    I assume the 'sleave' where the plunger sits gathers crap - as I had read of this I had checked it by splitting the valve pushing the soleniod part and the plunger part. It all moved freely without any resistance. I also filled one side of the plunger up with Carb cleaner to detect leaks but none of the carb cleaner leaked through the other side - so it seals when closed.
    Gazza4
    PRESTON
    You guys with the 150 dth engines, when you clean your EGR's, particularly on higher mileage cars, it is also worth removing the throttle body and cleaning the inlet manifold where the exhaust gasses pass back into the engine from the egr. Odds are it will be almost completely blocked there.
  1. Cleaning egr
    By morrisseyno1 in forum Troubleshooting
    Last Post: 4th September 2011, 20:16
  2. CDTI - carb cleaning exercise 020911
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2011, 17:36
  3. DPF DIY Cleaning
    By Beckman in forum Diesel Engine related
    Last Post: 17th July 2010, 20:26
  4. Checking and cleaning Injectors on my 1.9 CDTi SXi 150?!
    By VXR CDTi in forum Diesel Engine related
    Last Post: 13th November 2008, 16:22
  5. cleaning
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2007, 12:08
