Results 1 to 1 of 1
Thread: Best h.i.d's
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Thumbs up Best h.i.d's
    I think I should let every know, I think the H.I.D Lights with the Ceramic covering are better then the standard HID Lights you find, the beam light is much more horizontal and straight and sends less glare to other users the metal base helps with the fitment and the ceramic bit definately works to keep the bulb from heating up to cause damage to your ball / headlight cover.
    I have listed a seller below, check out the difference. These are the ones I am using.
    As there are 35w you will definately need a H.I.D Decoder to cancel it from coming up on the OBC.
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=330379335700&Category= 23009&_trkparms=algo%3DLVI%26its%3DI%26otn%3D2
