Results 1 to 10 of 11
Thread: knocking noise from rear
    Oct 2010
    N. Ireland
    Default knocking noise from rear
    Hi,
    My vectra 56 cdti 150 has a slight knocking/rattling noise from rear while driving along rough/uneven roads. There is no noise on smooth surface. Would it be most likely the drop link rods?
    Also after reading on here, should I clean the ERG Valve, boost sensor and throttle housing to avoid future problems.?
    Car is approaching 80k. Going to get timing belt done, water pump then.
    Sep 2010
    Hartlepool
    Don't know about the knocking. Have you checked your exhaust?
    Also, EGR valve, boost sensor and throttle housing cleans are done by quite a few members every 3 / 6 months and are really easy if you follow the How2's posted on this site. I've just done mine for the first time by following the How2's and advice from others and car is running the best it has done since I got it.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Could be drop links, arb bushes or upper control arms. Easiest way to diagnose UCAs is to grab the road wheel at 12 o'clock and tug it sharply, if you hear a knocking noise they need replaced.
    The arb bushes are not so easy to diagnose as even although the look ok the could still be the problem
    Oct 2010
    northumberland
    Probably drop links or anti roll bar bushes
    Regular Member PORKBALLS29's Avatar
    Epping
    Does the rear have drop links? As I have the same on my Signum. Tried tuggy the wheel on the front and nothing. Even tried tugging the drop link when of full lock and doesn't seem to be any play. But cant work out if its front or rear.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    This will sound daft, but have you checked the two side storage compartments in the back for anything loose? I carry a few simple tools in mine, and have them wrapped to stop rattles.
    north east
    boot lid rattle ?
    if so some insulation tape aroudn the metal post on the catch fixes it ;-) 2 or 3 turns round it.
    Oct 2010
    northumberland
    In the past i have had same probs on various cars, to test if its the drop links i have removed it normally two bolts easy job and then drove over uneven road, if noise aint there bingo, if its still there its not the drop link wont cause any harm to car but dont go driving miles with it removed
    Oct 2010
    N. Ireland
    Thanks lads for all your replies, its deff not exhaust, items in rear compartments or boot lid rattle. I'll jack her up and see is there any movement at wheel. Its nothing serious, but will have to get it sorted for first mot.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    If your doing the test for upper control arms as I suggested, do it on the ground
  1. Knocking noise from rear
    By IrishVectra in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2012, 20:40
  2. knocking noise from rear
    By Lozza in forum Suspension, Wheels & Brakes
    Last Post: 1st May 2012, 18:35
  3. knocking noise at rear
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:54
  4. Knocking noise from rear
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 20:36
  5. knocking noise at rear.
    By piker john in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 17:39
knocking rattling sound vauxhall vectra c rear
