Thread: Help required after Parrot install.
    Jul 2010
    Stoke-on-Trent
    Default Help required after Parrot install.
    Hey everyone,
    First off just want say i did search for this problem but only found one thread with some relevance.
    I have recently fitted a Parrot bluetooth kit to my 02 Vectra C.
    The Parrot works fine, but the headunit will not allow me to enter the code to get it working again, the date is just flashing on the display screen, and the headunit seems to be going on and off repeatedly (the power/volume button is flashing)
    Does anyone have any ideas what so ever?
    I read it may be that the hu is stuggling for power because of the parrot?
    Many thanks in advance everyone!
    Andy
    Regular Member NealM's Avatar
    Mar 2007
    Cheshire
    Vehicle : Pre-Facelift
    Trim : LS
    Engine : 1.8 Petrol
    Hi mate
    You're right the HU is struggling for power. I've just fitted a Parrot to my 52 plate Vec C and had EXACTLY the same problem.
    You need to power the Parrot independantly from the HU using a switched live, you can pick one up from the back of the ciggy lighter.
    Jul 2010
    Stoke-on-Trent
    Thanks Neal, but would this then mean that if i put anything in the lighter.. i.e. satnav.. that would also have insufficient power due to the parrot?
    Ashington, Northumberland
    It will be fine. Whatever you plug into the ciggy lighter will still work perfectly. Taking power from the back of the ciggy lighter is the globally accepted method of powering the parrot kits.
    Jul 2010
    Stoke-on-Trent
    Thanks guys!
    Ill have to have a play around this weekend with it.
  1. Parrot install
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2013, 20:43
  2. My Parrot mki9200 install
    By Niall83 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 19:11
  3. show me your Parrot install please
    By Big Knox in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2010, 10:49
  4. Parrot 9200 Install Help
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2009, 09:22
  5. Radio problem after install of parrot kit.
    By kenp in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2009, 13:30
