Results 1 to 10 of 16
Thread: Signum Boot Lock
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    Default Signum Boot Lock
    Well ours decided to die on us but got in through the inside with the screwdriver trick and then it started working again then stopped so got a new part. Matt fitted it tonight and it still won't open, any suggestions?
    CORNWALL
    Anyone got any ideas?
    Full Member Big Sig's Avatar
    Has he fitted it correctly? does it unlock from the door switch and the key? have you tried both?
    CORNWALL
    When you open the drivers door nothing like normal, open all the doors the boot pops open but doesn't uncatch so you got to push down on it to shut it. That was the old one, new one mmmm... not sure as I was out when he fixed it last night.
    Ok he says it's doing the same thing with the new one.
    Jan 2010
    Glasgow
    Quote Originally Posted by Matt&Jemz View Post
    be ready to 'catch' it as it pops and open it fully. then close it again, lock car, and try again. my signum done the same but fixed itself by doing this...
    When you unlock all the doors the number plate lights come on, this then should allow you to open the boot as its unlocked - not pop open - fairly sure you know this already. Maybe its the actual lock in the boot and not the microswitch in the handle. I take it that its well greased?
    CORNWALL
    No idea but will try both ta. Just a pain in the rear with the car at the moment, one thing after another
    CORNWALL
    Sorted cheers, was the switch/handle whatever it is the button thing not contacting. So now we have a brand new boot catch no longer needed!
    That's quite common on signums. Thought that was what you had already replaced
    CORNWALL
    We'd done the bit that looks like this not the bit under the rubber handle bit!
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. Boot Lock
    By alancallaway in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2012, 18:35
  3. boot lock
    By alden11 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:04
  4. Boot Lock
    By arnage25 in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2006, 22:21
vectra c and signum boot lock the same
