Thread: Vibration
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    Default Vibration
    At idle...What would cause a vibratrion to be felt through the drivers seat...the steering wheel also you can see vibrating?
    I do get when letting the clutch what feels like an engine mount moving when taking up the drive..also sometimes when i start it up i get alot of engine movement..feels like engine movement unless it something else..
    08-plate sri cdti 150 model...it drives fine
    its had all the dmf changed but the service mannager said in his opinion the movement you feel when your just about on biting point he says is the flywheel and wants to fit another...just not sure how this is..so over to you guys...
    Can see it having another few days in the dealers...trouble is i'm away to germany in 2-weeks so its gotta be spot-on..roughtly 2300 miles round trip in 4days so its going to be tested.
    preston
    sounds like rough running
    check egr / boost sensor
    change air /oil /fuel filter
    as for flywheel, dmf is flywheel therefore if its been changed it shouldn't need changing unless its been fitted badly
    Oct 2009
    LINCOLNSHIRE
    Its just had all the filters changed at the dealer...i cleaned the boost sensor..was cacked up but boost wise its fine and pulls like a train...
    Random starting sometimes feels like a mounts got alot of play in it...and feels like the engines moving alot...again unless something else is out of sync...
    It doing very good mpg so baffled rearly...got no lights hanging on at start-up...
    preston
    i guess mounts might be an issue...what mileage have you done
    otherwise check all hoses ....boost...intercooler is your in and around that area......worth checking
    and i'd check throttle body and clean
    Oct 2009
    LINCOLNSHIRE
    its done a nats off 45k..so most of its life spent on the motorway...i know most of the intercooler hoses in theory should of been checked because the front bumpers been off because it had the aircondensor replaced so you would of though if any were holed it would of been seen...
    Would the throttle body seriously cause vibrations on idle?
    preston
    on here we've worked out that EGR /boost / intercooler / maf / crankcase venting are all interlinked and therefore unpicking faults is somewhat hit and miss
    without warning lights / codes i'd be tempted to look for mechanical solution but keep the others above in the back of your mind
    throttle body or egr are my guess for your problem if your mounts are ok......
    otherwise is your swirl bar ok????
    cheers
    Oct 2009
    LINCOLNSHIRE
    Swirl bars not loose...its had EGR when they replaced the turbo about 500miles ago..reckon i'll pop and see the serive manager..he's fine and fitting bits i've never know a service manager like him...
    Only issue i'm thinking is..leave it to progress and knowing my luck in germany it goes tits up...but without codes your in the dark i guess.
    Regular Member Exclusive BV's Avatar
    West Midlands
    Have you looked at the engine while somebody else start it up?
    Could it perhaps be the exhaust system moving around underneath?
    north east
    Can i put 50 p on the front engine mount needing replacing ?
    Oct 2009
    LINCOLNSHIRE
    Went to the dealer today and saw the service manager..just walk in the garage part and go upto his window in the wall and pop my head-in..start yapping like you do and talking about the issues above...
    Ordered a new boost sensor...the one that sits near the landing panel...gonna do that on friday..then pop it on the ramp and see if anythings un-toward underneath...like he said to me loads we can change yet under warrenty...he's a star nothings to much trouble for him and he loves warrenty work...
    We'll get there in the end...he's old school and wants to sort the problems out..top guy..i'll let you all know if it does any good.
  1. vibration
    By steve19cdti in forum Engine & Drivetrain
    Last Post: 11th April 2011, 07:32
  2. 2.2 sri vibration
    By lordreeson in forum Engine & Drivetrain
    Last Post: 27th October 2010, 19:44
  3. vibration
    By rich2507 in forum Engine & Drivetrain
    Last Post: 21st April 2010, 17:12
  4. Vibration through car
    By Orbilator in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2008, 21:13
  5. vibration
    By Eddy R in forum Engine & Drivetrain
    Last Post: 20th August 2007, 19:59
