Thread: leaking exhaust
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Default leaking exhaust
    hi muckers
    i have a zaffy 03 and it is leaking and knocking on the underside,i took a look and there is a connection piece or flange that connects the bottom of the manifold to the main exhaust system ,the flange is loose and you can turn it and move it about can anyone tell me if i can just replace the connector or have i got to replace the lot
    ive lost my lead to connect phone to computer so i cant do any pictures sorry
    kind regards
    PRESTON
    What engine is in the Zaffy?
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by barney490 View Post
    ita a 1.6 muck
    PRESTON
    normally they just bolt on with three bolts and a gasket. If the flange is still there,but the bolts are missing, you should be able to bolt it back together with new bolts.
  1. Oil leaking onto exhaust
    By djlee in forum Engine & Drivetrain
    Last Post: 22nd February 2013, 11:43
  2. I am leaking
    By KevinG in forum Engine & Drivetrain
    Last Post: 19th February 2011, 21:29
  3. Leaking exhaust
    By dave16v in forum Engine & Drivetrain
    Last Post: 20th April 2008, 10:23
  4. Sounds Like A Leaking Exhaust ??
    Last Post: 12th April 2008, 16:35
  5. Oil leaking from somewhere.
    By jayd in forum Engine & Drivetrain
    Last Post: 10th April 2008, 20:50
