Thread: The pins to diag plug for gid
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Default The pins to diag plug for gid
    do i need to plug the pins in to the plug so they are the same as the other pins on the diagnostic plug go some spare pins with wire on two if anyone wants a few
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    What do you need to know Paul.
    The pin outs from GID to Diagnostic Plug ?
    If I remember correctly, the screen plugs is
    Green on pin 22 goes to Diagnostic plug pin 3
    White on pin 23 goes to Diagnostic plug pin 11
    If it helps, the Low Speed CAN green goes from the CIM module to Diagnostic plug pin 1
    Does that help ?
    This is the same for all 32 pin Vectra display plugs..
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    am struglin to under stand i have two wires left that need to go to the diag do i need to take the diag plug out then insert the pins the same as the others
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    You should already have the green wire on pin 3 and the white wire on pin 11 of the diagnostic plug.
    It would be a good idea to take the plug out, even if it is just to confirm that the two wires are indeed there.
    If you don't have wires here already, then yes just insert new pins into these positions.
    otherwise,
    Splice the green wire into the one on pin 3 of the diagnostic plug
    and splice the other white wire onto the one on pin 11.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Do these two images help.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    thanks mate so the two wires that are left on my gid i dont need to connect the the diag plug then mate
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    which two wires are those?
    What colours do you have left?
    and from which pins on the screen connector.
    There are only three wires from the GID to the Diagnostic plug on the Vectra-C
    (More on the Vectra-B and Omega-B as these aren't even half CAN devices, where you may have an extra brown/white, or brown/green, or brown/yellow.)
    The three wires you should have to diagnostic plug are:
    Brown/white for half CAN Vectra only (Diag Pin 8) - display pin 14
    There is no brown/white on full CAN Vectras
    Green for all Vectra-C (Diag Pin 3) - display pin 22
    White for all Vectra-C (Diag pin 11) - display pin 23
    If the display still doesn't work, then it is from the wrong model of Vectra...perhaps Vectra-B
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    no the screen works mate my car is half can sorry its a 04 i need the stalk activatein but some one said there is two wires you need from the gid to the diag plug
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    No probs Paul, I checked your profile for car spec, however I covered both full and half CAN options for other members reading this thread.
    With regard to you saying that it is working,
    In that case, you can ignore the comments about the extra 2 wires.
    I assume you got that from Bigmac's thread, for upgrading from 18 pin to 32 pin display plug. (TID to GID conversion)
    If you already had a 32 pin plug, then it would have already been fully populated.
    No probs, it is just a basic fit the stalk, and then Tech 2 / Vaux-com or Op-com job to enable to stalk switches in the variance configuration tables.... simples !!
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. blue plug display into a grey plug vehicle
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 23:09
  3. Tech2 diag
    By magpie27 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2009, 11:03
  4. U581 Diag Tool
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 21:37
  5. Bluetooth Diag Reader
    By Cragy in forum Vectra C / Signum Troubleshooting
    Last Post: 19th February 2008, 10:50
