Thread: Urgent! How to refit seatbelt adjuster on b-pillar inside trim??
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Urgent! How to refit seatbelt adjuster on b-pillar inside trim??
    Hi guys, I'm in a bit of a pickle.
    I have just done the rear interior light mod on my Estate.
    I couldn't get the headling down without taking the B-Pillar trims off.
    The trims do go back ok but the front seatbelt height adjusters are loose. They move up and down and the seat belt doesn't seem to lock.
    Is this right? How do the trims go back??
    Bit worried now as I need the car tomorow and its starting to get dark!
    Help!!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    its just to find the correct point and the press inwards.. takes 20 when you find the correct.. but you have to remove the seal between the door and body, to get them in correctly.
    Jun 2006
    North West
    Cheers for the reply.
    The seal on both sides?
    Theres a sort of inner box that the seatbelt sits in. This is clipped to the trim and then theres the locator at the top.
    Also on the back of the height adjuster theres a white plastic thing (no idea how to explain it. I assumed that this would need to connect or rest against the seatbelt adjuster itself?
    If its all clipped in right, does that produce enough force hold hold the seatbelt adjuster locking thing in? (Again I don't know how to explain it)
    It feels as if these are all in correct. I'l give it another go then.
    Engine : 2.2 Direct
    yes that sounds right.. i remember the pain when i had my rooflining down. but it was someting like that "fitting in a fitting in a fitting" like you discribe.
    Jun 2006
    North West
    Does the weatherseal just pull off and push back on?
    Engine : 2.2 Direct
    yes.. else you wont have it sitting properly around the door
    Jun 2006
    North West
    Thanks for your help Kenp
    I managed to get them back on properly. Its a pig of a job getting them on right. Took me nearly 2 hours. Doing it in the dark didn't help.
    Taking the weatherseal off does help. But it was getting the mechanism in the right place that was tricky as it kept moving out of place when you pushed the trim back in place.
    I took a few pictures, so I will do a How2 for it.
    I'm never going to take them off again!!!!
    Engine : 2.2 Direct
    Quote Originally Posted by Marky View Post
    Until next mod
    that you got it working again.. may i recoment a
    next time :
    Jun 2006
    North West
    You are so right. Thats exactly what I needed.
    Because I needed both hands free I was holding a mini-LED torch in my mouth.
    Engine : 2.2 Direct
    I need one too im droooooling when im holding my led light in my mouth so its on my wishlight
    (the one on the picture, is actually capable of ligthing up a road 125 meters infront of you.. "only" cost 70£)
  1. Pillar trim
    By heheshamon in forum Bodywork & Interior
    Last Post: 10th March 2010, 20:18
  2. Car door pillar trim
    By @ndy-e in forum Bodywork & Interior
    Last Post: 4th February 2009, 16:10
  3. Irmscher Pillar trim kit
    By Graeme in forum Parts for sale
    Last Post: 26th May 2007, 18:52
  4. A pillar trim removal.
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2007, 21:03
how seat belt rests in pillar
