Results 1 to 10 of 15
Thread: Diesel reek on acceleration
    Sodding Typical on Sea
    Default Diesel reek on acceleration
    One of the main reasons I decided to let my clocked Vectra go is that I get a lot of diesel reek out the back when I accelerate, not intermittently but every time I accelerate.
    I got the wife to follow me home after the dealer checked out the Turbo (which I am told is perfect) and she noted that on the motorway slip road and any other medium to hard acceleration I got a cloud of grey or black(ish) smoke.
    Does anyone know what this could be from?
    stockport
    Arrow
    Quote Originally Posted by Derek Mc View Post
    Hi Derek.Sounds like it was over fueling.You usually get that sort of smoke when the engine is under load or when you have a tuning box fitted.FELIXX.
    No tuning box fitted a standard car as best I can tell it used to mean to me a well worn engine, but this one has only 55K on it
    stockport
    Arrow
    What comes out when its been standing for a while?,if its burning oil it could be seeping back into the cylinders through the valve guides.
    This will show on start up as a great big cloud of blue smoke as it burns the oil in the cylinders.If it doesn't clear and start running normal but continues to puff out blue smoke it could be that the oil rings are f****d.If you have any doubts whatsoever,get a compression test done.That way you will know one way or the other.FELIXX.
    Quote Originally Posted by felixx View Post
    Not blue smoke its dark grey or blackish and is visible enough that with my back to the sun on the slip road I could clearly see it myself driving the car so is well outside normal tolerance I would say.
    But Felixx, this particular car is going back tomorrow so isn't a long term worry just wanting to know if this sort of thing is to be expected as I don't think it is.
    stockport
    Arrow
    Sorry Derek,I thought you were concerned about the new one you are obviously getting.(I thought you had picked it up already).FELIXX.
    Nah tis the old one, I seriously swithered over keeping it but wondered about the reek as it was a bit odd???
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Sounds like overfuelling, for whatever reason.
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Quote Originally Posted by Grumpy1954 View Post
    Yep classic overfuelling symptoms (on a standard motor). Black/dark smoke from diesel on accelaration.
    Usually the car's way of saying it needs some tlc. Fuel filter, dirty injectors, manky inlet, etc. Usually pretty easy to put right.
    EVERYWHERE
    Grey smoke is usually caused by injection/injector problems.
    Black smoke is overfuelling.
    Blue smoke is burning engine oil.
    White smoke is coolant issue or condensation from exhaust.
    You can also have a combination of any or all of the above.
  1. Acceleration help please
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 1st July 2011, 23:02
  2. HELP! No Acceleration
    By Aidi in forum Engine & Drivetrain
    Last Post: 4th April 2011, 14:52
  3. Diesel reek!
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2010, 20:15
  4. Dip in acceleration...
    By Stevie-B in forum Engine & Drivetrain
    Last Post: 23rd April 2008, 15:03
  5. 3.2 Acceleration
    By jamesr in forum Engine & Drivetrain
    Last Post: 16th March 2008, 13:23
