Results 1 to 10 of 19
Thread: Vec C twitchy Front end
    Sep 2010
    Milton Keynes
    Default Vec C twitchy Front end
    Recently bought this car and the front doesn't give me the feedback I would expect. Feels very light almost to the point of unstable at times in relation to my old B. tracking has been done and tyre pressures are correct. Have been told steering rack is ok (although by someone at Kwik Fit)
    Any ideas or is this just a characteristic?
    Sep 2010
    Milton Keynes
    Also wobbles slightly when braking hard
    Aug 2010
    Antrim
    Its a Vectra!!!!!!!!!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The slight wobbling when braking hard is more than likely to be warped front discs.
    When KF checked the rack did they check the track rod ends etc?
    Sep 2010
    Milton Keynes
    Yes. Had a look myself although what I know can be written on a stamp. All looked clean and good. Agree with the possibly warped disc diagnosis but would this have passed an MOT 2 months ago?
    Its the general not quite in control thing on the front end. tends to follow uneven road surface etc
    Aug 2010
    Antrim
    Yes a car can pass an MOT with slightly warped discs. My wifes Hyundai did. It was noted as something likely to need attention before the next test. You seem to be describing tramlining which tends to occur more with bigger wheels and wider tyres etc.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    As long as the discs physically look ok and it can give the correct efficiency in the brake rollers than it will pass an mot no bother
    Oct 2010
    northampton
    depends where mot was done to weather it went on brake rollers as thats a part of the test that vosa dont see so the tester can put what he/she likes but as long as they wrk well they should pass anyway
    i had this judder and new discs and pads solved it i also had a wiring noise on braking too now gone
    Oct 2010
    northampton
    my 235 40 19s are a sod for tramlining
    Sep 2010
    Milton Keynes
    215's cause tramlining?
  1. twitchy rear end
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2013, 17:51
  2. Really twitchy around corners
    By Geoff644NI in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2011, 22:33
  3. Twitchy Rear End
    By Mini the Minx in forum Suspension, Wheels & Brakes
    Last Post: 27th June 2010, 04:02
  4. Twitchy front end on 2.2 sri 03
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2009, 09:53
  5. twitchy signum
    By Martybhoy in forum Handling & Braking
    Last Post: 18th February 2009, 21:32
