Thread: cambelt change
    france
    Default cambelt change
    I am planning to change the cambelt on my 2006 vectra 1.9cdti. Would it be wise to change the water pump at the same time? Would appreciate any comments from more experienced members.
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    Yes, most people change the water pump at the same time.
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    I've always been told it should be done at the same time, easier to do when its off and if that fails then goodbye belt.
    france
    Thanks guys, I'll do just that. When I had a renault Trafic I was advised to do the same but was not sure of the Vectra.
    The waterpump is the main cause of belt failure. Yes, wise to change it at the same time.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Just done mine along with a cambelt kit!, pump failure at 62k!!, please remember to put sealant on the bolt threads!!, I also put a little on the bolt shafts, this is required due to the bolts going into water & oil cavity's.
    Jun 2009
    Northern Ireland
    I've just been off the phone to Vx. They told me timing belt change has been reduced to 80k miles and that it would be wise to change the water pump at the same time. The mechanic also told me that he has seen water pumps fail well before 80k miles.
    I think I'm gonna change my timing belt at 40k as the scare stories are all too common. Between 40 and 50k miles seems to be the most common failure time. It doesn't help that my car is now 6 years old with 38k on the clock. For the sake of an extra £50 for the waterpump I think it's well worth changing.
    Sep 2009
    Aylesbury
    1.9 cdti 150..
    how much did you pay to get the cambelt and waterpump replaced??
    Mar 2007
    Gloucestershire
    Quote Originally Posted by dreams3577 View Post
    1.9 cdti 150..
    Just paid £220 cash at my local indep garage - that was for MOT, service, cambelt and water pump. I supplied the belt and pump and bought good quality OE parts for £108 delivered. and got the stamp in the book!
    Mind you I did push my luck as car had 102k on the clock, so I was driving around nervously for a bit.
  1. cambelt change
    By chappie in forum Introduce yourself.
    Last Post: 28th April 2009, 07:48
  2. DIY cambelt change
    By bigcarman79 in forum Engine & Drivetrain
    Last Post: 14th May 2008, 20:31
  3. 3.2 cambelt change
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 12th May 2008, 21:46
  4. Cambelt change £140-160
    By jamesr in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2008, 11:46
  5. cambelt change
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2006, 04:02
