Thread: oil change 1.8
    Jan 2006
    milton keynes
    Default oil change 1.8
    any one got any ideas about an oil change in a 1.8 with the spinoff metal filter? just bought new filter and oil from vx filter is a long life one (which is surprisingly small compared to the normal ones.
    cheers peeps
    lift and support ther car, remove sump plug and drain oil..loosen filter and catch oil that drains..fully remove filter.
    refit sump plug with new seal..smear oil seal on new filter with clean oil and screw back on to full hand tight..
    refill car with oil, capacity in handbook..
    start car and check for leaks..
    Jan 2006
    milton keynes
    while i was checking around the underside of my car it took me ages to find the sump nut.... turns out on my car its a torx screw..... i was expecting something like a 15mm nut.... bizzare.
    nope..VX swapped over in the late 90's...
    my V6 is torx, but the wife's 2.2 is a hex head, as is my old mans CDTi 150..
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
