Thread: Diesel Leak-Off Test vs Diagnostic Software
    Wales
    Default Diesel Leak-Off Test vs Diagnostic Software
    Bit technical this - does anyone know if doing a diesel injector leak off test is better/worse/the same as the injector reading information you would get from something like opcom or Tech 2?
    The injectors used on the CDTI seem to use a special inverted connector, so you cant just squeeze a piece of pipe over the end of the leak-off and do the test. You can buy the connectors for about £5 each, or I could get the car connected to a diagnostics machine, and that would tell me something about the condition of the injectors
    Which if any, is better? I am trying to diagnose poor-ish MPG figures BTW
    Engine : 1.9 CDTi
    What is it you want to know about the injector?
    If you have access to an oscilloscope you can see using that.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the fuel return leak off test has to be done mechanicaly ...ie you put the tester pots on each injector and do the maths the raw data from the ecu isnt acurate on the flow back fig .....
    Wales
    If injector or injectors are duff and as a result, maybe giving poor MPG.
    No oscilloscope to hand buddy!
    Wales
    Quote Originally Posted by benny View Post
    Thanks mate. Thats what I wanted to hear - leak-off test it is then!
    Wales
    Just thinking abouth that answer again benny, would diagnostics be accurate on any other value (say spray pattern for example).
    I dont have a preference whihc route I go down (i.e. leak-off test or diagnostics) I just want to check the injectors as fully as possible.
    Feb 2006
    dudley
    the only reall way to test is either to remove and inspect or leak off test ...leak of test is only a guide tho ...wnt tell you what is wrong just that you have a fault ..also how bad is the fuel econ ?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    [QUOTE=snapsnap;1345882]Bit technical this - does anyone know if doing a diesel injector leak off test is better/worse/the same as the injector reading information you would get from something like opcom or Tech 2?
    Thanks[/QUOTE
    What type of mpg are you getting? to make you think there low'ish.
    Wales
    Thanks benny & wizard. Sound like a leak-off test is the way to go.
    Im getting about 42MPG at roughly 60% urban, 40% motorway BTW, this is based on many 1000's of miles driving. CDTI 120 1.9
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. diagnostic software
    By veralum in forum Suspension, Wheels & Brakes
    Last Post: 25th January 2010, 10:55
  3. Diagnostic Software & Cable
    By Bernie Mac in forum Engine & Drivetrain
    Last Post: 1st June 2008, 14:29
  4. Where's the diagnostic port & can you get Software to hook PC up to car ?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2006, 13:55
1.9 cdti leak off test
