Results 1 to 10 of 11
Thread: Painting advice before work starts tomorrow please !
    Wales, UK
    Default Painting advice before work starts tomorrow please !
    Hi all,
    Already had some good advice from Jezzy and Keithy but one more question. Here are some pics below.
    Basically, there was two small areas that had a bit of paint missing. I picked at it and to my suprise the paint almost fell off for some reason ?!? So I carried on , thinking it would be best to start from scratch. Now, Ive come to a point in which the paint will no longer peel off....
    1) Do I get a heat gun, lightly blow over it and finish what I started >
    2) Do I sand the edges down, where ive picked, so its smooth and carry on as normal by roughing up the rest of the bumper and priming it ?
    Pics to explain my problem.. Thanks all
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    I would sand it as flat as possible mate, then use a plastic prime/builder with a few coats, sanding between each to make sure you have a completly smooth finish
    Wales, UK
    Cheers mate, so you mean you would not bother to take any more paint off, just sand the edges flat, build it up with a few coats of primer, but using wet&dry inbetween ?
    Jan 2008
    Dundee
    i would try sanding it flat (if you can) then just keying the rest.
    However if you cant get it totally flat. Strip the whole lot off.
    Some clear coats can be a nightmare to sand flat
    Wales, UK
    Thanks mate, will give it a go. Just found your progress thread. your car is coming along nicely mate!
    Jan 2008
    Dundee
    Yeah, got all the grilles in today but having major problems getting the bumper sitting correctly at the wings
    Regular Member squekey's Avatar
    bedfordshire
    hello mate, i would say to sand the whole bumper down as if you have got area's flaking then its better to be safe than sorry as could well mean person before didnt use plastic primer which would cause the paint to flake off.
    Wales, UK
    Quote Originally Posted by Keithy View Post
    Sure you will sort it out, ive hear they are a pain to get right. Im hoping my new bumper goes on ok...
    Quote Originally Posted by squekey View Post
    True, didnt think of that. Its hard to flake off now, so will give it a little heat and see what happens.
    Thanks both
    bedfordshire
    no worries mate, let us know how you get on with it, also dont forget to give the bumper a good clean with panel wipe before priming up.
    Wales, UK
    Sorry guys, what colour primer ? Does it make a difference ?
  1. Replies: 30
    Last Post: 19th August 2011, 01:08
  2. Replies: 28
    Last Post: 12th August 2011, 23:06
  3. House Painting & Decorating - Corner/Edge Painting advice
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 14th January 2011, 17:45
  4. Well it all starts tomorrow.....
    By Orka The Porka in forum General Chat
    Last Post: 9th January 2007, 23:04
  5. Work starts at Courtenays
    By Sparkyvxr in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2006, 14:09
