Results 1 to 10 of 11
Thread: Instruments all dead.?
    Aug 2010
    Leeds
    Default Instruments all dead.?
    Got in car last night found all clocks dead no speedo, fuel gauge, rev counter, this was in vauxhall only 10 days ago for a new steering coulmn and i wonder if a plug has come loose.
    Has these instruments ever failed before like this? If so may be a common fault.
    Full Member paul.sessions's Avatar
    leighton buzzard
    sounds like it could be a plug mate. but i think something to do with the alternator etc.. i have seen this posted up a few times before. i would take it back in and blame them
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Could be a loose plug or it could be the ABS plug, some cars have a similar fault to this and it's rectified by cleaning the contacts on the abs pump plug
    Bit too coincidental though
    Regular Member rmg1's Avatar
    Limavady, N.I
    Vehicle : Vectra C Sri V6 CDTi
    Engine : 3.0 V6 CDTi Z30DT
    Mileage : 121000
    Mines done that about 2 weeks ago and it turned out to be a loose fuse. I think it was fuse 17 on the passenger side of the dash board.
    Aug 2010
    Leeds
    Quote Originally Posted by rmg1 View Post
    Spot on that man just after i posted this i went and checked the fuses pulled each one out on the passenger side and non blown but after putting them all back in it worked.!!
    A good result a lesson learnt.
    north east
    ^^ was going to say what that fella did but he beat me to it and you know that now :-)
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    THEY'RE DEAD !!
    ALL DEAD !!
    WWWWWWHHHHHHHHHHHHHHHHHHHYYYYYYYYYYYYYYY ?!?!?!?!?!?!?!?!
    preston
    Intruments on mine went dead tonight on way back from morrisons, no speedo, rev counter, temp/fuel gauge, indicator warning lights, oil warning etc but had dash illumination and cruise worked. removed and refitted the 2 blue fuses, f12 and f17 and now all ok. wierd
    WGAF#5
    its now becoming more prevalent as the colder inclemant weather kicks in and condensation starts to cause slight corrosion on contacts
    expect a few more "contact related" faults to become apparant as the weather declines
    north east
    Spray the fuse box with wd40 is your advice then deztroyer?
  1. Loss of instruments
    By tangoman in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2009, 07:54
  2. Replacement instruments .
    By Suffolk Boy in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2009, 20:54
  3. Instruments go dead
    By astrocat in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2009, 00:32
  4. What instruments....
    By lofty in forum The 'Off Topic' room
    Last Post: 5th November 2008, 04:09
  5. No Instruments or Radio?
    By pauls898 in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2007, 20:17
