Thread: Arch rolling
    liverpool
    Thumbs up Arch rolling
    anyone on here ever had there front archs rolled on there vec c ?
    am running 20's on about a 60mm drop (coilovers) and its catching the arch every now and then on different angles
    i want to get them rolled so i can lower it down more , and just wonder if anyone has had this done as the lip isnt really that big
    the rear is fine btw due to the way the camber in more when lower
    if it cant be done am thinking about having the front wheels machined down for a lower offset or as a last resort fitting a smaller profile tyre
    cheers
    jeff
    Regular Member hagga's Avatar
    kingswinford
    This may help.. looking at putting 20's back on at some point
    http://www.vectra-c.com/forum/showthread.php?t=114160
    liverpool
    thanks matey so it can be done
    may save me a few quid , and can get more lows on the go
    kingswinford
    Quote Originally Posted by lazy_arse_pie View Post
    yeah..I had 20's on before with 45mm drop.. but needed to do archwork when i fitted 19's(wider offset) so i know my 20's will go back on no probs now.. gimme a shout if you need more 'diy rolling' info.. I should have took more pics and done a 'how 2'
    liverpool
    yeah you should of done , i may leave it to the pro's though at only £25 an arch
    am running about 60mm but there ET35 and wana run it on the bottom of the coils
    kingswinford
    Thats not a bad price.. you'll have no probs once they're rolled.. the only probs i had was with the 19's as they were a 235 tyre on a 8" rim opposed to a 235 on a 8.5" rim.. the slight stretch took it away from the arch on the 20's.
    liverpool
    am rollin 245 35
    kingswinford
    yeah you'll sort that no probs.. i know the lip is short, but after flaring mine too gained a good 8mm+... you may need to mod your liners.. i had to chop mine back a little but am going to get some more so i can extend them.
    liverpool
    sounds good to me , cheers
  1. rear arch
    Last Post: 15th November 2012, 00:34
  2. sri arch liner
    By alan15153 in forum Bodywork & Interior
    Last Post: 17th May 2012, 13:48
  3. Wheel Arch Gap
    By sturgi in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 16:49
  4. 20s and arch clearance
    By Cossy in forum Handling & Braking
    Last Post: 22nd June 2010, 17:48
  5. Arch Gaps
    By chris_20 in forum Styling
    Last Post: 19th August 2006, 13:42
vectra c arch roll
vauxhall vectra c rolled arches
