Thread: ANGEL EYES halo lights
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Default ANGEL EYES halo lights
    Read all the various posts regards angel eyes and changing 501 incandecent lamps for 501 LED's
    Thinking of getting Angel Eye's and HID's so have couple of questions
    So can i wire the halo LED's/relay in such a way through the Cigarette Lighter light that the Halo's act as DRL's ?????
    Is possible to fit sidelight lamp in the area where the idicator fits thus having the advantage of reflector behind it.saving putting it in the fog light
    Jul 2010
    Bump
    Jul 2009
    The Rift, Cardiff
    Wiring to the cig lighter will work but when I did it I used an empty fuse socket in the engine bay thats live with ignition on. Or you could wire them to the cig socket illumination grey/yellow wire so they come on when you unlock the car. Dont forget to add an in-line fuse.
    Personaly I wouldn't put a side light in with the indicator, as it would probably make the indicator less noticeable, just tuck it away.
    Jul 2010
    Quote Originally Posted by ChrisBilly View Post
    Understand your comments re wiring.
    Re: side lights tucked away would'nt it fail MOT??
    Would the Led's in the Halo's be bright enough in daylight??
    Jul 2009
    The Rift, Cardiff
    Where I say sidelight I mean a standard T10 501. The halo's are fine as sidelights and will pass an mot as long as the light is white. I haven't done it yet but i'll be putting led t10's in my side lights wired to the grey/yellow and tucking original bulbs behind the headlight units. I think leemarksmith has wrapped them in foil which seems a good idea.
  1. Angel eyes
    By PAULMAC77 in forum Styling
    Last Post: 22nd December 2009, 18:36
  2. Angel Eyes or Dark Lights?
    By Blagmeister in forum Styling
    Last Post: 21st January 2009, 19:15
  3. Help with angel eyes
    By stubopvectra in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2008, 08:52
  4. DIY Angel eyes "Halo"
    By Woodsta in forum Styling
    Last Post: 27th February 2007, 14:10
signum halo fog lights
