Thread: Changed 2.2DTi aux belt
    Jan 2010
    Liverpool
    Default Changed 2.2DTi aux belt
    The Mrs' 2.2DTi had started squeaking something terrible when started from cold. I decided it was the aux belt and went to the local motor factors to buy a replacement. They didn't have the correct size so £15 later I was on my way home with a belt thats 5mm longer than the standard one.
    Once I had the belt off I noticed that the tensioner had roughly 2 cm of play in its 'untensioned' state. Not side to side play, but movement in the way the tensioner applies tension to the belt. Has anyone else noticed this?
    I was concerned that it may have been the tensioner causing the noise, but the pulley spins freely and smoothly and the tensioner movement is silent, too.
    Anyways, the belt went back on and tensioned nicely. The extra 5mm didn't cause a problem.
    I started the car and it stayed silent. Yay! Job=success.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    well done mate good job
    Jan 2010
    Liverpool
    Ta. She's a pain in the backside with cars.
    If only she realised sooner that her MOT was up last Friday. (She noticed on Wednesday) It went in and failed on a rear suspension arm bush. It cost her £96 to get it changed by the garage.
    I could have done it for £15-20.
    On two occassions I've driven two of her cars (this is one of them) and I've noticed the rear brakes are grinding. I've got round to changing the pads and discs and there has been nothing but backing plate left on the pads!
    The flipping dafty.
    Last edited by Mogsy007; 9th October 2010 at 21:33. Reason: Lol, a word I wouldn't have thought would be filtered, was filtered.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    nothin new lol i look after my lassis car
    Regular Member lostdog's Avatar
    Oct 2010
    Midlands
    Mogsy007....have you got pic or a how 2 for the belt change? my is making noise.....cold start....
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The aux belt is easy to change, pull up on the tensioner, release belt, fitting is the reverse.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    tensioner vibration causes the bolt holes to open out not putting the full tension it
    Jan 2010
    Liverpool
    Quote Originally Posted by lostdog View Post
    No pics or How To, sorry. Its quite straightforward to change the belt, but can be fiddly routing the new one and getting it over the tensioner at the same time.
    I removed the airbox to get access. Also the covers behind the drivers front wheel are in the way, so remove them, too.
    Quote Originally Posted by the-wizard View Post
    Whilst it may be easy, having three hands would have made it a breeze.
  1. need timming belt changed anyone up for it??
    By rozzer2006 in forum West Scotland
    Last Post: 24th October 2012, 10:48
  2. Anyone changed a 2.0 / 2.2dti turbo before?
    By Innes in forum Diesel Engine related
    Last Post: 28th February 2011, 13:06
  3. Cam belt changed at last...!
    By si_sri in forum Engine & Drivetrain
    Last Post: 4th July 2010, 19:16
  4. first cam belt changed
    By kdadidog in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2009, 18:51
  5. Cam belt - is there a way to tell if it's been changed?
    By andreitone in forum Engine & Drivetrain
    Last Post: 29th August 2009, 17:26
vectra c 2.2 dti aux belt
zafira dti aux belt change
signum 2.2 auxiliary routing
signum 2.0 dti aux belt
vectra c auxiliary tensioner failure
vectra c 2.2 direct aux belt tensioner noise
vectra c 2.2 dti belt
dti aux pulley squeal
