Thread: Having trouble removing bumper!
    Sep 2010
    Rushden
    confused Having trouble removing bumper!
    This is probably a really easy thing to do but im havin trouble removing the bumper, I have looked at the 'how 2' however after removing the 3 screws in each wheel arch I went under and located the 4 rivets, however they wont budge!...they wont push up and release it looks like the middle pin over laps the bigger head - if that makes sense? iv tried pulling,pushin and hittin! but to no avail!
    Please help,
    Cheers,
    Carl
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    You to pull out the centre pin as that is what expands the clip.
    Once that is out the clip should come out.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    And word of advice, once you do get them out, dump the centre pins and use self tapping screws in stead. Put the main clips back in but with self tappers through the middle instead of the pins. Does the same job and you can unscrew them next time, those pins are *****es to get out
    Full Member spennny's Avatar
    Blantyre
    Thats a good tip there mate
    Sodding Typical on Sea
    Quote Originally Posted by Ian-Highlander View Post
    How brilliant an idea is that!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Is this the front or rear causing probs? I only had two screws in my (rear) wheel arches, had no need to remove front yet.
    Sep 2010
    Rushden
    yes mate the front
  1. Help. Trouble with removing front and rear door cards.
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2012, 14:54
  2. Having trouble removing centre section
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2010, 15:06
  3. Trouble removing oil filter cover on 3.2
    By fuzzbomUK in forum Engine & Drivetrain
    Last Post: 17th June 2010, 18:23
  4. Bumper trouble
    By pops034ever in forum Bodywork & Interior
    Last Post: 25th February 2010, 13:27
  5. Removing rear bumper
    Last Post: 10th February 2007, 17:42
