Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: All revs no go!
  1. #11
    Aug 2009
    herts
    Mine is intermittent, Ive noticed I get the spanner light on when I have the car set to pre ignition position with the key, until the glowplug light goes out. The spanner will go when I turn the car on.
    Sometimes, when starting later in the day after the first cold morning crank, the car will fly through the gears sometimes, i notice, if I hold the key in the pre ignition position until the fuel pump is heard primed, and then cranked the car can accelerate sluggish and be intermittent on and off in its acceleration, sometimes holding back, and sometimes going full beans.
    If on the secondary starts during the day after the cold morning crank, and no further glow plug warning lights during these times, I get in and turn the key straight away it feels better.
    I am aiming towards a glow plug issue myself having read on here.
  2. #12
    Regular Member Princess D's Avatar
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    After messing about with it last night I found a split in the turbo pipe so I've ordered a new one of those and out of curiousity I removed the new glow plugs and put the old ones back in which stops the spanner light staying on permantly - it goes on for a few minutes when starting the car and goes off itself!
    Im beginning to think the lack of performance is due to the pipe as I read that someone had a similar problem and new piping solved it! unfortunately I won't get the piping til wednesday so I'll have to do my 250 mile trip with my car acting like a 1.1
  3. #13
    Regular Member DaveW555's Avatar
    Cannock
    gaffer tape the pipe up with some really strong tape where its split and it will last you til the new one comes. should give you your performance back as well.
  4. #14
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    oh cheers! I'll put some on when I get home - didn't want to tape it incase I put the wrong type of tape on and it wasn't strong enough and would cause more problems!
  5. #15
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Changed the small rubber bit but couldn't get the pipe out of the vac lol ... it was getting dark and since theres no electric in my garage I decided to just do a quick fix! As I need the car for University and work this weekend!
    And it makes one hell of a difference!
  6. #16
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    glad you got it sorted
  7. #17
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Good to see it's sorted too.
    Gazza4
  8. #18
    Sep 2010
    Anglesey
    Engine : 1.9 120bhp
    Mileage : 28k
    Cheers guys
  9. #19
    Sep 2010
    Hartlepool
    The boost vacuum hoses do tend to perish and split on Vectra's.
    You might also want to check the other small tube that can be seen in the top right of the photo that you posted above. This is part of the same boost vacuum system
    I changed mine not long back for the 4mm silicone tubing (There's a thread / How2 on here somewhere) and the car feels great.
    HTH
  10. #20
    north east
    I like what you have done there I have the 4mm silicone hose waiting around for when that joint finaly fails but I have been reloctant to fit it yet as im worried about it collapsing with it being so soft.
    Am i right in thinking you have just changed the elbow joint and connected to the existing hard plastic tube ?
  1. revs low in neutral
    By dan21 in forum Engine & Drivetrain
    Last Post: 8th August 2012, 19:25
  2. 3k revs and thats it.....
    By johnaw in forum Engine & Drivetrain
    Last Post: 11th January 2012, 18:44
  3. revs
    By steelee in forum Vectra C / Signum Troubleshooting
    Last Post: 17th November 2011, 23:02
  4. Mis-Fire Low revs
    By hutless56 in forum Engine & Drivetrain
    Last Post: 31st January 2009, 17:30
