Results 1 to 10 of 14
Thread: Liqui Moly Diesel Throttle Valve Cleaner - Any Good???
    Sep 2010
    Glasgow
    Default Liqui Moly Diesel Throttle Valve Cleaner - Any Good???
    I have come across this product (Liqui Moly Diesel Throttle Valve Cleaner) online and it reads well. Used an equivalent on a Petrol Passat before and it made quite a difference. Surely would beat taken the intake off to clean and reassemble - or will it?
    Any feedback on either method would be really great as I am rapidly approaching the 100k mark and have just cleaned EGR (a doddle) and boost sensor (5 Minute job).
    Naturally if anyone wants to order it and try it for me better yet
    May even be worth a group order from good old Germany
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Best way to clean the "throttle body" and manifold is drive the car at 125mph for 100 miles. Worked wonders on my V6CDTi
    If I were you I'd take the intake off and soak it in petrol Should clean it nicely
    Sep 2010
    Glasgow
    Or 70mph in 4th gear I suppose. That would be about the same airflow
    Do I need to mess with the timing belt when I take the manifold off???
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I don't think you do no.
    EVERYWHERE
    The so-called "throttle" valve serves different purposes on the 1.9 and 3.0 engines.
    On the 1.9 it appears to be an electronically controlled device used to aid exhaust gas flow when the EGR valve is opened and on the 3.0 it only seems to serve the purpose of being a 'shutdown' valve, the same as it does on the DTI's.
    In either case a bit of cleaning wouldn't go amiss.
    Bristol
    Vehicle : CDTI 150
    As correctly stated by diesel dog; in a common rail diesels the EGR is used throughout the rev range. The 'butterfly' allows the ECU to control the amount of air flowing in to the manifold during EGR operation.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by diesel dog View Post
    I would say it is a 'shut down valve' (as mine gives a 'shake' when I switch the engine off) on the 1.9's as well as being for emissions control.
    Gazza4
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    70/4th you would be better doing 90 in 3rd!, Easily achievable with the cdti 150 (without going into the red!), Any-how's 'why' would you be wanting to ''clear'' out the throttle valve (body), If its connected to the 'old type manifold 'I' would just rip the piece of junk off!, Clean the other components, Then consider an oil separator divert! Job Done.
    EVERYWHERE
    Quote Originally Posted by the-wizard View Post
    With 215/50/17 tyres fitted, the 150 Vectra's achieve a genuine 80.77mph @ 5000rpm with the 1.321 3rd gear ratio and its 3.55 final drive ratio.
    Which is exactly the same speed that my V6 gets (allowing for speedo error) with the same gearing.
    http://www.kabamus.com/garage/gears.html
    See other thread.
    Which is what many with the 1.9 engine have done.
    Not keen on the open to atmosphere ones though, particularly having discovered that the fumes coming from them are actually highly explosive hydrocarbons!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    dd it's only the final drive and possibly the 6th gear ratios which are changed to accomodate the extra torque.
    Gazza4
  1. Which diesel cleaner
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2012, 15:31
  2. Swirl valve Cleaner ?
    Last Post: 15th December 2009, 19:31
  3. Replies: 7
    Last Post: 2nd July 2009, 17:51
  4. Diesel cleaner!!
    By ACE.TAG in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2007, 17:22
  5. STP Diesel Cleaner
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 19:32
liqui moly diesel throttle valve cleaner
