Thread: Air Rad/FMIc ??
    Regular Member Marcosuk's Avatar
    Fife
    Question Air Rad/FMIc ??
    Hey guys, got a quick Q......
    In the Z20NET, if you were to remove your air con rad & blank off the pipes, would that create a better air flow to the FMIC??
    Could your move the FMIC & radiator a bit closer if air-con rad were to be removed??
    I dont use air-con & it needs re-gassed anyway, but i'd use blanking nuts incase i wanted to re-fit it for selling etc?
    Or.... Would this just be pointless?? Just need some thoughts...
    Cheers Marc
    Fife
    No one with any input?? Surely someone has done this to help the airflow??
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    I was thinking about removing my condenser to improve air flow to the intercooler on the diesel but was unsure if it would make any difference
    Fife
    More colder air getting to the intercooler... Must be a better solution??
    Dont want to upgrade the intercooler just allow a better flow.. Mean having to loose the air-con rad on the NET tho
    Admin plasma's Avatar
    On the Forum
    291 Post(s)
    Engine : 150
    Mileage : 74000
    I fitted one at the front in the direct airflow, no better during normal use but when the weather is hot it still runs fine and doesnt suffer heat soak
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. fmic on 150 cdti
    By chrisg in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2011, 21:54
  2. Fmic...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 12:17
  3. FMIC First Impressions....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2007, 22:08
  4. FMIC Stage One...
    Last Post: 13th September 2007, 13:33
  5. Fmic Ok Vxrd
    Last Post: 7th September 2007, 23:19
