Thread: Non Starter
    Oct 2010
    scotland
    Unhappy Non Starter
    wondering if anyone has any ideas
    2.2 dti sri vectra, car was running fine then coughed cut out and died, has refused to start since
    had it on machine and come up with the following codes
    P0340
    P1590
    mechanic says that even with these codes car should start but wont
    turn the engine over and it wants to start but just wont
    any ideas welcome
    Regular Member johnnyallen's Avatar
    London
    Fault code P0340 is camshaft position sensor, when I had my Omega, I had one of these fail and my car wouldn't start, just turn over.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    THINK I remember seeing this on the Corsa site I'm on. Cam position sensor.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P0340 is cam position sensor circuit malfunction.
    If the sensor has gone, it is relatively easy to change. Firstly though check the wiring and plug, as it can become damaged or not make a good connection.
    Oct 2010
    scotland
    ok thanks guys i gonna have a look and see if its this, will post and let u know
    Oct 2010
    scotland
    Y22DTR engine in this model, parts shop says this model does not have a camshaft sensor is this correct??
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I missed the 2.2 DTi bit.
    In reality I am not sure. The old 2.0 DTI didn't have a cam pos sensor. I wonder how it comes up with an fault on something that it doesn't have.....
    Regular Member elongmoss's Avatar
    Burton-on-Trent
    had the same thing exactly on my 2.2 dti the camshaft position is monitored in the fuel pump as its driven off the camshaft via a chain
    mine required a new fuel pump ouch
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Maybe a slipped link? It would probably be worthwhile checking the timing of the crank, pump and camshaft positions
  1. Non-starter
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 19th July 2012, 18:32
  2. vec c possible starter ??
    By neilb1 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2012, 16:50
  3. non starter
    By marky1 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 17:06
  4. starter or DMF???
    By mark82 in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2010, 11:33
  5. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
vectra c 1.9 cdti sri non starter
vauxhall vectra 2.2 fault code p1590
