Results 1 to 10 of 16
Thread: Oh no - P1191 - Fuel Pressure
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Default Oh no - P1191 - Fuel Pressure
    So Ive been getting a spanner light appearing briefly every so often, plugged it into laptop today, Ive got one error code, P1191 - Fuel Pressure System Malfunction.. Garrrr.. Car is running ok though... Its an 05 z22yh Vectra.. It has original regulator and pump on by the looks of it.. Am I right in thinking my first job should be to get the fuel regulator replaced? And am I also thinkiing correctly that a VX dealer should do that free of charge for me, even though my car is 5 years old??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If there's a recall on it m8, then yeah it should be done at no cost to you.
    Gazza4
    Jul 2010
    Buckinghamshire
    Thats what Im not sure of, if theres a recall that covers my car (age) I dont really fancy ringing up a dealer sounding like a beggar trying to get work done for free..
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by nibblitz View Post
    On reading this thread you seem to be in the middle if you look at the concerned partys' profiles.
    http://www.vectra-c.com/forum/showth...gulator+recall
    Gazza4
    Sep 2010
    london
    new ones only cost £30.00. u could pull the vacuum off. if theres no fuel in that it aint bad
    Jul 2010
    Buckinghamshire
    What do you mean vacuum? Do you mean a hose connected to the regulator? and if it has no fuel in it then regulators ok? Does a faulty regulator leak fuel into a vacuum hose then?
    30 quid? I'll do it myself then.. Easier than driving 20 miles to my nearest dealer... Where from can I get it for 30 quid matey?
    Sep 2010
    london
    I would do a fuel pressure test first, your replacement pump maybe no good, also check your MAP sensor, TPS and see if you got any fault codes stored in your engine controler. Since that regulator is controlled by vacuum, then there is just a rubber diaphram and since you said there was no fuel in the vacuum line when you pulled it then no its not bad. dont know wherer u buy them. my m8 did tho
    Sep 2010
    london
    this is wat my m8 tol me
    Jul 2010
    Buckinghamshire
    I havnt replaced the fuel pump yet, and I wouldnt know how to do a fuel pressure test.. I thought the fuel pressure regulator just has an electric plug connected to it.. Can somebody else confirm.. Its only this one error code my car has, and its still running fine, the spanner light doesnt stay on, it comes and goes.. I think the regulator should really be the first thing to try swapping out as that seems to a part generally identified as being no good, some people had it done as part of a recall.. Anybody know the cheapest place to obtain a regulator? Thanks.. :-)
    Sep 2010
    london
    lol lol i aint really sure how to do them but my friend emailed me this wen i had a prblem. he fiixed it for me as i werent sure m8. maybe a meckanik wuold know?
  1. P1191 - Fuel Pump or Regulator?
    By danhariga in forum Engine & Drivetrain
    Last Post: 27th August 2013, 20:01
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. P1191 - fuel rail pressure sensor circuit low input
    By L11Marc in forum Engine & Drivetrain
    Last Post: 17th March 2009, 17:12
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  5. fuel pressure?
    By beefycol in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 12:31
vauxhall p1191
https:www.vectra-c.comforumshowthread.php119892-Oh-no-P1191-Fuel-Pressure
p1191
p1191 fuel pressure opel vectra
fuel pressure feedback opel
p1191 - fuel pressure system malfunction
p1191 fuel pressure requlator circuit malfunction possible caseess
signum fuel pressure sensor feedback circuit low
vectra c fuel pressure sensor pin out
p1191 vicale code dezire
p1191 and p0301vectra c
vauxhall vectra 2.2 p1191 fuel rail system malfunction
p1191 Fuel pres reg rng
insignia low fuel pressure
p1191 opel fuel pressure system malfunction
Fuel pres reg perf P1191
