Results 1 to 10 of 14
Thread: 2.0dti intercooler pipes collapses!
    Kent
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default 2.0dti intercooler pipes collapses!
    help with this one please
    sorting out my 2.0 dti, when you rev it to get the turbo working it lacks in power, and on checking the intercooler pipe coming from the engine to the intercooler is folding flat.
    i have checked the inter cooler is not blocked and found to be ok. also tried removing the airbox to rule this out and it was still the same
    any ideas on what else to check?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    turbo might not be spinning
    Kent
    Trim : SRI
    Quote Originally Posted by benny View Post
    any way of checking?
    Feb 2006
    dudley
    remove the intake air pipe and have a peek inside ....
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Can you hear it?
    Have you tried taking the pipes off to check their condition, the dti's commonly blow pipes so its possible that the pipe has degraded inside causing it to collapse
    Kent
    Trim : SRI
    Can you hear it?
    hello
    can not remember 100%hearing the turbo would have to recheck this one.
    the pipes were in good condition other than them folding flat
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Did you look at the insides of the pipes?
    Regular Member Innes's Avatar
    Plymouth
    I have heard of them splitting but not going flat. Its almost like there is suction in the pipes rather than positive pressure. You havent mistakenly put the turbo on back to front?!??!?!?!!?
    Is it all of the hoses that are collapsing or jsut the one?
    If its just the one hose then I was say it has degrafed from the inside. The oil can eat away at the rubber. Vauxhall used crap hoses on the 2.0 and 2.2dti's.
    Kent
    Trim : SRI
    yes i did as i had to change the rad pack so had them all off
    was just looking at the vac piping from the actuator the vac pipe run up to the the sensor at back of airbox fine, checked the pipe that comes of from that and runs across front of engine and the T's off where it T off and goes to the engine this was unpluged.
    would this cause the problem? not able to test it due to it being in the garage and the time of night lol
    Innes it was all the pipes going flat.
    Plymouth
    Does the engine stall? The engine sucks air in and there has to be a blockage some where for the pipes to go flat. Have you looked into the air intake that hidden behind the grill and goes into the air-box? Do you get the the car/spanner light on the screen on the dash?
  1. Intercooler pipes.
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 23rd September 2012, 08:59
  2. Replace 2.2DTI intercooler pipes?
    By kenno31 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2012, 11:14
  3. Oil misting in intercooler pipes....
    By martyngell in forum Y & Z30DT Specific
    Last Post: 24th February 2012, 23:41
  4. oil intercooler best place to get replacement pipes from
    By bert01909 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 18:38
  5. 2.2 dti intercooler pipes
    By peadar in forum Diesel Engine related
    Last Post: 3rd March 2011, 21:57
intercooler pipe collapsing
vectra c 2.0dti intercooler pipes
vectra 1.9 cdti intercooler pipe collapses when revvedintercooler hose collapsingcitroen c5 diesel intercooler pipe collapsingrenault trafic intercooler pipe collapsescollapsed intercooler pipe symptomsturbo pipe collapsing vauxhall cavalierintercooler pipe calapsing renault traficVauxhall vivaro turbo pipe collapsed
