Results 1 to 10 of 18
Thread: Question about electrics on throttle body
    middlesbrough
    Default Question about electrics on throttle body
    I have a question that I thought someone out there might be able to answer, took my throttle body off today and cleaned it as it was coked up the question is this , the part next to throttle body that is enclosed it plastic, when we took the lid off where the electric circuit board is was covered in what looked like really runny wattery oil, should this oil be there ? ? ? ?
    hopefully the answer is no and I can go out and buy a new throttle body and my car will run smoothly , oh and its an 05 vectra c , 1.9cdti , 150 auto
    thanks John .
    Farnborough, Hampshire
    Hi john, i cleaned mine out completely and didnt cure the issue i was having. I know gazza has had more success by removing the plate as he thinks it may be closing when it shouldnt be. Could try that before buying a new one?
    middlesbrough
    Quote Originally Posted by danman487 View Post
    I have pm'd Gazza as it was him that put me onto cleaning the throttle body out in the first place, thanks
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Jsud2002 pm replied to m8
    Yeah the plate was closing effectively shutting the engine down.
    My theory behind it is that some electrical fault had developed - open circuit on the PCB etc and it made the Throttle body think that the engine had been switched off hence, it would shut over. The valve is spring loaded in the 'open' position so something had been trigering the TB electrics to shut the valve over - imo.
    Hope you get it sorted.
    As for the oil, it shouldn't be there m8.
    Gazza4
    Sodding Typical on Sea
    It now looks like the shaft seal allows oil past due to the pressure in the intake and it fills up this unit and eventually causes it to fail!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Derek Mc View Post
    Typically its the electrical joints on the PCB which give up - the oil doesn't help the stepper motor though.
    Gazza4
    middlesbrough
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Had a look at the joint and all seemed ok but ya need ****** good eyesight to check , think I might take it off again and resolder them all anyway , cant do any harm by doing this , oh and thanks for the pm Gazza , didnt realise they could be that expensive , think your right though, gonna deffo make sure it is this before purchasing new one.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by jsud2002 View Post
    No worries bud.
    Gazza4
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Anyone have a pic of the soldered joint that can break?
    Might have to check mine.
    Just answered my own question. There is a very nice how to here: http://www.vectra-c.com/forum/showthread.php?t=119346
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Marky View Post
    Just beat me
    Also there could be a connection issue too.
    Gazza4
  1. Throttle body question
    By McLovinH in forum Engine & Drivetrain
    Last Post: 28th August 2012, 22:01
  2. Throttle body question
    By Loftuz in forum Engine & Drivetrain
    Last Post: 18th April 2011, 13:58
  3. throttle body question
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 16th January 2011, 16:51
  4. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
  5. Throttle body question
    By sirnapper in forum Engine & Drivetrain
    Last Post: 8th August 2009, 14:35
