Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Injector seals 2.0 Dti
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Default Injector seals 2.0 Dti
    I seem to be getting more and more white smoke on startup and it smells of diesel the mechanic who did my tech2 today said he thought it was injector seals so im thinking of paying them to check the seals first,they said they check it with a vacuum pipe on leakoff nipples.
    My question is
    Is this a reliable way of telling the seals are leaky ?
    Irmscher Insignia CDTI 130
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Is the car using oil?
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Nope not using oil and its deffo diesel smell mate only does it when sat for an hour or over night
    Regular Member benny's Avatar
    Feb 2006
    dudley
    if you smell diesel and have white smoke your barking up the wrong tree with the seals ...the seals allow the fuel to return to the tank hence the none start there isnt any fuel in the system ...i would be looking at the swirl bar in the inlet manifold and the inlet manifold trackt for cokeing up ....or sticking swirl flaps .. a vac test will check if the seals are ok ...one ruff way is to check if there is engine oil in the leak off pipes a direct way to say the seals are on there way out ...
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Cheers benny but looking on numerous forums regarding white smoke and diesel smell they all seem to say its a common problem with the Y20DTH and thats seals
    Dont think the Y20DTH has swirlflaps plus sometimes it takes a good 7 or 8 cranks to start then i get a cloud of smoke and then it clears
    Feb 2006
    dudley
    y20dth was the first vx enigne to have swirl flaps for starting ... the white vac pipe on the front of the engine is where the swirl flaps are you will see a leaver with a vac diaphram on it this leaver should move freely .....and the lower part of the manifold needs to be clean ..... one little test is disconect the coolant temp sensor and see if that makes it better to start if it does it needs a ecu reprogram ....
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    It starts better on glowplugs if i turn my key a few times to heat plugs up it starts first time with no smoke but it hasnt been cold enough for them to come on.
    So if i unplug coolant temp sensor it will chuck glowplugs on yeah ?
    Feb 2006
    dudley
    yes it will chuck them on ...but that isnt the test ...the vec diesel has had a weak ecu map and it some times comes out ...there was a feild rem for it some where ... im not saying it isnt the seals but it is worth doing a few free checks before spending lots of cash ....
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    So if i do that tomorrow morning and it starts without smoke after getting glowplugs warmed up what will it be ?
    Feb 2006
    dudley
    plus if it is the seals the fault would be the same every time ..giveing it more glow plugs wouldnt make a difference the fuel will leak back to the tank all the same if you follow me ..
  1. 2.2 dti injector seals
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 29th September 2012, 16:45
  2. Could this be injector seals or??
    By gmclorn in forum Vectra C / Signum Troubleshooting
    Last Post: 18th February 2010, 14:06
  3. Injector seals
    By suggs1971 in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 22:02
  4. Injector seals!!
    By siz1 in forum Engine & Drivetrain
    Last Post: 13th October 2009, 19:20
  5. injector seals
    By tditony in forum Vectra C / Signum Troubleshooting
    Last Post: 6th May 2009, 20:10
y20dth swirl flap www.vectra-c.com
2.0 dti injector seals
