Thread: urgent help needed grrrr
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default urgent help needed grrrr
    My crankshaft pulley snapped of today, so bought a new one, tried to remove the remains of the old one, by taking the 4 torx bolts out but couldnt remove the remaining bit of cs pulley, so rang vx and they said that some pulleys are bolted throught the middle too, so going of what they said i removed the centre bolt and walla, the pulley came free, and also the inner pulley that the cam belt goes around grrrrrrr
    my problem and i hope some body can please help me, is how do i align the cams up now? ive heard there are no marks on the casing around the cams. I dont have any cam tools, so what do i need to do guys,
    please help me as i need my car desperatly
    thanks in advance
    edit : its a z19dth 1.9 cdti 150
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    anybody help please????
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Quote Originally Posted by Rapala View Post
    Hi pal, did have a read of that but problem is I can't use that method as the timing is now out due to the inner crank pulley coming of with the outer pulley
    Any other suggestions please?
    PRESTON
    as i recall, the crank pulley has a keyway in it that lines up with the crank, so can only go on one way. So long as the engine hasnt been turned over, then the timing shouldnt have moved and you should be able to refit the pulley using the big centre bolt first, then check the timing marks, then refit the big pulley with the four small bolts and rebuild.
  1. URGENT help needed
    By vectraedition100 in forum Engine & Drivetrain
    Last Post: 27th February 2012, 20:21
  2. Urgent help needed !!!!!!! Please
    By bert01909 in forum Engine & Drivetrain
    Last Post: 18th September 2011, 19:14
  3. Urgent help needed
    By Topcat4500 in forum Engine & Drivetrain
    Last Post: 11th February 2011, 19:39
  4. Urgent help needed ! !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2010, 22:01
  5. Urgent Help Needed!!!!!!!
    By Tibs in forum Electrical & ICE (including SatNav)
    Last Post: 24th November 2007, 00:21
vectra c z19dth crank pulley key
