Results 1 to 10 of 18
Thread: Alternator or CIM
    Regular Member johnnyallen's Avatar
    London
    Default Alternator or CIM
    Hello everyone, this morning on school run, my car went berserk, when I started it up, I noticed the dash and display dimming slightly more than usual, but put it down to being a cold morning, then 10 mins away from home jammed in traffic, the dash, info display and all lights started flashing on and off, but only when I reved the engine up to drive, when idling everything was fine. Also the overload relay behind the glovebox was clicking on and off
    First thought was oh my god, the CIM has gone, but when I got home, I checked the voltage on the battery and got the following :
    Engine Off in Sleep mode : 12.7v
    Engine idling : 13.8v
    Engine reved to constant 1000rpm : 11.2v to 16.9v (hunting up and down)
    To me it sounds like the voltage regulator has gone on the alternator and the spike in voltage is causing the overload relay to trip, what do you guys think please?
    Thanks John
    Engine : 1.9 CDTi
    Your diagnostic sounds correct.
    The alternator shouldn't be putting that much voltage out no matter what.
    London
    Phew thank god for that... now a trip to fleabay!. Out of interest, does any veccy C alternator fit or ire they all specific to enging besides the amp output?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    It could be a 100 or 120 amp mate. Do the two halfs interlock or just line up next to each other, I take it you have s 1.8 or 2.2 petrol?
    London
    Its a 2.2 mate, and is the 100amp version, just wondering if just replacing the voltage regulator would be best, or just gamble on a complete 2nd hand unit.
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Did you measure the voltage by DIREDTLY probed to the battery electrode?
    Or to the connector nearby?
    It's not normal for a battery voltage rised to 17V and dropped to 11v.
    Your diagnostic is sound right, but i would check the battery and connection first.
    London
    OMG just tried to get the alternator out, all fine until the last bottom centre bracket bolt, cant get a spanner or socket onto it because of the flippin air con pipes in the way, whoever designed this engine needs my breaker bar wrapping around his neck. Checked all the connections around it, everything sound, Anyway, grazed nuckles and a bad back later I put it all back together and started it up, all seemed fine until about 10 mins later then it went nuts again. I'm gonna go and cry in the corner now.
    London
    Quote Originally Posted by yysnet View Post
    Yes mate on the battery itself, connected op-com too to watch the system voltage, and that shows similar fluctuations, plus fault code for overload relay and no communication to CIM.
    Jul 2010
    Scotland
    Bless, GM is really a bad design. you have to go down the car like a rat for a oil filter change.
    Vehicle : SRi
    Mileage : 137000
    Eh? The filter change is probably the easiest I've come across on any car. Pop the hud, and there it is facing upwards towards you.
  1. New Alternator
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2012, 00:50
  2. which alternator
    By john1 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2011, 13:32
  3. Alternator
    By m8wos in forum Engine & Drivetrain
    Last Post: 10th December 2011, 20:54
  4. what alternator do i need?
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 14:50
  5. alternator
    By hitcho in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 21:01
vectra c 13.8 alternator voltage
