Results 1 to 10 of 17
Thread: Coolant Temperature Sensor Location
    Sep 2010
    Hartlepool
    confused Coolant Temperature Sensor Location
    Hi,
    As well documented in other thread(s), I am having problems with my car "hesitating" and having a loss of power.
    It has been suggested to me that it COULD be the coolant temperature sensor faulty and giving the ECU intermittently faulty signals and it overfuelling the engine.
    Does anyone know where this sensor is located on a 54 reg 1.9 CDTi 150, how much a replacement is to buy and if it is a DIY or garage job to change it?
    I can't find anything on here to do with this sensor except threads where people are suggesting it may be faulty.
    Sep 2010
    Hartlepool
    BUMP
    Come on guys, someone out there MUST know something!
    Full Member Big Sig's Avatar
    They are usually screwed into the thermostat housing.
    Sep 2010
    Hartlepool
    Which is where? I only know a little bit about cars.
    A specific description or, even better, a photo pointing to where it is would be greatly appreciated!
    Oct 2009
    Luton
    Sensor is PN 55193203, located in the thermostat housing (see the passenger side end of the cylinder head). Simple job.
    Sep 2010
    Hartlepool
    I don't suppose you could be a gem and take a photo of it and it's exact location for me could you please?
    I've never had to look for one of these and have no idea at all what it looks like / where it goes.
    Thanks.
    Follow the water hoses.
    Sep 2010
    Hartlepool
    OK. I'll try!
    See how much skin I shred off my hands in that narrow(ish) gap! lol
    Sep 2010
    Hartlepool
    Thanks Big Sig! That's Great!
    So, when I get in there, would I just disconnect an electrical connector at the top of the sensor and unscrew it from the housing?
    Also, how much is the sensor to replace and do the stealers usually carry them on stock?
    Apologies for all the questions mate.
    No idea if they are even available separately, you might find you have to buy the whole thermostat housing C/W sensor. Call them and ask
  1. Coolant Temperature Sensor
    By Basher1 in forum Troubleshooting
    Last Post: 2nd October 2012, 22:26
  2. External Temperature Sensor Location
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2012, 21:02
  3. coolant temp sensor on a z20net location
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 08:54
  4. Coolant temperature sensor
    By Sambor in forum Engine & Drivetrain
    Last Post: 21st April 2011, 06:39
  5. outside temperature sensor location
    By crucial in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2011, 14:06
vectra temperature sensor location
vauxhall vectra temperature sensor location
vectra c coolant temperature sensor
location coolant sensor on insignia
vectra coolant sensor location
vectra c coolant temperature sensor location
vectra coolant sensor switch
coolant temp sensor vectra cdti
where is the water censor situated on a vauxhall vectra energy
vectra c coolant temp sensor location
vectra ect sensor
vectra c water temperature sensor
vauxhall zafira dti coolant temperature sensor location
vauxhall zafira coolant temperature sensor location
vauxhall vectra coolant sensor
vauxhall vectra coolant temperature sensor
how to flush out vectra c temperature sensor
ect senzor vectra c
vectra temp sensor
vectra c temperature sensor location
vauxhall vectra temperature sender
locatiin of sensor vectra water coolant
position of coolant temperature sensor 2007 vectra
vectra cdti engine coolant temperature sensor location
