Results 1 to 3 of 3
Thread: Clutch pedal noise
    Newbury
    Default Clutch pedal noise
    Hi, I have a 1.8 LS 2002 vec c. I was able to fix a clutch return issue (which also fixed the cruise control) so that made me feel better, but one thing it did not sort out was an irritating noise coming from deep behind the steering colomn eveytime I release the clutch pedal. I can't think of a word that describes the noise, but it sounds a bit like a spring or something metal catching. Has anyone had this issue or advise what it could be (relay?)? thanks.
    (couldnt find anything using "search")
    Regular Member Craig1985's Avatar
    harwich essex
    I've got it too, bit of wd40 every few months is a fix for me, ****** annoying and loud. Sounds like a creak as you lift your foot?
    Newbury
    well actually mine sounds like a small squirt of compressed air as the pedal lifts up. (no f@rt puns!)
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. clutch noise when pedal depressed
    Last Post: 22nd October 2012, 23:19
  3. clutch pedal
    By Tam80 in forum Engine & Drivetrain
    Last Post: 2nd September 2010, 19:41
  4. Clutch pedal noise
    Last Post: 11th December 2009, 06:15
  5. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
corsa c clutch pedal air noise
insignia clutch pedal noise
