Thread: 1.8 misfire
    Kent
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default 1.8 misfire
    right got a 1.8 z18xe that has a misfore, pluged upto opcom come up with misfire on number 3
    now i got told the ecu has gone, but what do you guys think? would the ecu gone cause this?
    or would i be best trying a new coil pack?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is it a regular misfire or occasional? Does it do it on every firing stroke?
    Firstly, you need to understand if it is fuel or spark related. Are any wires to the injector for that cylinder damaged? Is the spark plug OK? Have you removed the plug and checked? Is the coil pack fitted securely?
    It may be that the ECU has gone, but no point in changing an expensive item until you have checked the simpler stuff first.
    Try moving the plug to a different cylinder and see if the misfire moves cylinders too.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Youve tried new spark plugs first I take it?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Who said the ECU has 'gone' and what evidence do they have to support this theory?
    Kent
    Trim : SRI
    the only thing i have done with it so far is check the plug is ok on the coil and its bolted down correct.
    i am yet to remove the plugs and check they are ok.
    the misfire is on every stock and is there all the time no mater what
    Kent
    Trim : SRI
    i will also being doing a compresion test when i remove the plugs just to rule out a droped valve but wanted to see if the ecu are know for going like this and not sure ont hese onthe vectra c lol
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    I think id start with a spark plug swap first, then look at the Coil pack if that doesn't work.
  1. misfire on 1.8
    By Lozza in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:57
  2. 3.2 misfire
    By noudder72 in forum Engine & Drivetrain
    Last Post: 29th November 2011, 23:05
  3. misfire?
    By ivesy in forum Engine & Drivetrain
    Last Post: 11th February 2011, 19:55
  4. V6 misfire?
    By lencuff in forum Engine & Drivetrain
    Last Post: 16th November 2010, 21:10
  5. Misfire
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2006, 16:30
vectra c 1.8 ecu misfire
vectra c 1.8 misfire ecu
