Thread: baffled
    york
    Arrow baffled
    when accelerating my 120 gives out a massive plume of white smoke litterally covers car behind doesnt smoke on normal revs but have noticed when i reverse it does it to , the engine seems to be running fine but doesnt use any fluids at all since service 18.000 mile ago it has used no oil at all or water so cant understand it .Only getting 34.7 mpg but it is a taxi
    Sep 2010
    Dumbarton
    Possible turbo problems?
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    White smoke is usually water burning in the cylinders... as to why its doing it if the levels not going down its hard to say... keep checking your coolant tank. Failing that when was your sedimenter last emptied??? One of your fuel filters is there to seperate water from the diesel and collects it in a small section of the filter housing with a drain plug which needs to be undone periodically to empty out the H2O...
    Normally it wouldn't let water up into the injectors and if it got full it would just stop the engine working as water doesnt combust (or we would have a cheap fuel bill) but if its a diesel and it may be burning water in the mix I would check that out.
    preston
    white smoke usually equates to water in the system somewhere
    things to check
    1) fuel filter replace and drain
    2) are you parking on a steep hill where water can enter the exhaust system
    3) check your oil for contamination
    after that get back to us
    cheers
    Bordon, Hampshire
    Before you pop down the garage check that out:
    http://www.ehow.com/facts_4897161_ca...-exhaust_.html
    Standard rule is white = coolant, blue = oil and black = overfuel... Just found out gray = underfuel lol! Might need to get that verified to fault find yourself before asking a garage to spend your hard earned cash doing it for you
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Thick pale/white smoke can also be ATF burning off a hot exhaust. I had a fluid pipe vibrate against the underbody many years ago with a Granada - ended up with a pinhole leak spraying ATF onto the exhaust downpipe.... I got halfway back from W. Germany being my own Red Arrow before things ceased to work halfway through Belgium.
    Check power steering fluid level and transmission fluid if yours is an auto.
    Sep 2010
    Dumbarton
    Reason i said turbo as a mate of mine had a golf mk4 and did the plume of white smoke under acceleration and turned out to be the turbo.
    Quick look on youtube http://www.youtube.com/watch?v=8M9OE...eature=related
    york
    wouldn say it smokes that much have just found that jubilee clip on plastic inlet pipe at front of engine will not tighten just slips but that is a tight fit antway car isnt parked on a hill but like i say its a taxi so it gets a battering but is well looked after
  1. A bit baffled,and nervous!
    By toaffer in forum Engine & Drivetrain
    Last Post: 7th February 2013, 20:24
  2. baffled?????????
    By eve01rton in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2013, 18:16
  3. Baffled by tuning boxes
    By Teapot in forum Diesel Engine related
    Last Post: 30th December 2010, 22:35
  4. MSN Baffled
    By JSYSH466Y in forum General Chat
    Last Post: 9th June 2009, 16:45
  5. baffled or unbaffled
    By alex in forum Diesel Engine related
    Last Post: 20th April 2009, 07:31
