Results 1 to 2 of 2
Thread: P0650-06
    Clitheroe
    Default P0650-06
    Hi guys (&gals)
    Still having the problem of engine cranking over for ages befor it finally "catches" and starts. Its a 1.8 Vectra C petrol.
    I have read the codes and the only one I get after clearing and retrying is P0650 - 06
    Now Iv'e done a search on here and though there are references to P0650 there is no mention of what the - 06 stands for
    Full errore code is P0650-06 Malfunction Indicator (MI) Circuit Low Voltage
    Could this be a reason for not starting properly.
    Can anyone explain the - 06 part of the code.
    RD
    Regular Member DaveW555's Avatar
    Cannock
    Autodata lists that code as Malfunction Indicator Lamp (MIL), control - circuit malfunction. Probable causes - Wiring, MIL, ECM
    Hope this helps
  1. B0670 and P0650 - error codes
    By CristianTM in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2016, 12:10
  2. Help explaining fault codes P0650 & P0400.
    By Signum-Steve in forum Engine & Drivetrain
    Last Post: 4th November 2012, 23:08
  3. P0650 mil control circuit malfunction code
    By bobsimes in forum Troubleshooting
    Last Post: 5th July 2012, 22:17
  4. fault code p0650
    By PeteRs in forum Engine & Drivetrain
    Last Post: 15th March 2009, 14:32
p0650-06 vectra c
fault code u2103-0 p0650-6 07 vectra petrol
p0650-06
p0650 vauxhall vectra fault code
signum 2.2 fault code p0650-06
p0650 opel
greska vectra p0650
P0650 opel vectra c klaida
opcom p0650(06)
Opel DTC P0650-2
