Results 1 to 10 of 13
Thread: electrics nightmare help!!
    Oct 2010
    south shields
    Default electrics nightmare help!!
    hi all, recently tried changing the drivers door module on my 2.2 dti as none of the controls worked i assumed this was the problem. anyway ordered one and it has came but with different letters on as my previous one had AL on in caps and this new one didnt.. dont know if that is a problem or not as they are both for drivers door
    now ive tried the new one not only does the door controls still not work but my cd player has no power and theres a "check safeguard" warning on my dash!
    any help please??????!
    Regular Member Dazzy2006's Avatar
    Notts
    Quote Originally Posted by jamie_hepp View Post
    was the switch new?
    Have you refitted the original switch because the check safeguard is to do with your alarm so if the "new" switch is faulty or the wrong 1 it will show the check safeguard message but i'm surprised it wasnt showing that anyway with the door not locking
    As for the stereo, hopefully u have just blown the fuse
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Changing the DDM requires a programming to be done. as its part of the Alarm/deadlock/security system.
    Oct 2010
    south shields
    how do u programme it mate?? also what fuse is for stereo... ive checked passenger fusebox and only one missing is fuse 22...
    Engine : 2.2 Direct
    you need a tech2 session at the dealers.. as vaux-com can program everything..
    Regular Member leonvectrac's Avatar
    south shields
    with your old one does it not just need fixing cos mine does it windows wont work but thers a fix for it on here some where if some one can find it, you can rub the contacts of the switch with a rubber or wet n dry am sure i read that some wer also check connections on old one cos if you can get it to work it would be better then geting a tech 2 session.
    south shields
    heres the how to here
    Oct 2010
    south shields
    i would try tht mate but the mirror dont work either does the central locking so cant be just the switch broke?... its gota be either the wiring a fuse or the module itself but cant work out which they all seem alright
    south shields
    strange, so looks like your gonna need tech2 session to pair new module
    Oct 2010
    south shields
    who do i get one of them off like?
  1. Been a nightmare.
    By JM53 BEL in forum Engine & Drivetrain
    Last Post: 31st January 2013, 00:15
  2. Nightmare
    By marko1966 in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2012, 19:26
  3. Another MOT nightmare
    By rockhopper in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 13:55
  4. ABS nightmare!!
    By jonno1103 in forum Introduce yourself.
    Last Post: 26th March 2011, 00:29
  5. Could my nightmare nearly be over.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2010, 20:45
