Thread: squeeky brake syndrome
    Liverpool....the red side
    Default squeeky brake syndrome
    hey guys just got my new vec yesterday but it has very squeeky brakes, is there any way to sort this out? maybe new brake pads etc??
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    I'm no expert but....I've heard in the past it can be a case of how the pads are seated in the caliper. A quick remove, Clean and refit with Copper Slip can sort it out. New pads may not hurt!
    Regular Member Harry's Avatar
    Uxbridge, London
    yep...copper grease or lack of it is usually a culprit.
    Ashington, Northumberland
    As above basically, strip them down, damn good clean up and a light smear of copper grease on all pad surfaces that touch metal (apart from the pad braking surface to disc obviously LOL). If you're putting the old pads back in, put them back in the same place they came out of.
    Just as he said Did this on both mine and Mrs D's cured it both times !!!
  1. Nutter on the bus syndrome
    By Grumpy1954 in forum The 'Off Topic' room
    Last Post: 24th August 2011, 20:04
  2. Vestibular syndrome
    By gibbon7000 in forum The 'Off Topic' room
    Last Post: 22nd October 2009, 20:25
  3. 2.0dti - spanner light syndrome!
    By Littleted in forum Engine & Drivetrain
    Last Post: 10th January 2008, 00:23
  4. squeeky breaks
    By stevietiger in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2006, 16:12
  5. squeeky brakes help!!!!!!!!!
    Last Post: 18th April 2006, 00:12
