Thread: Door Lock/Unlock buttons not working
    Sep 2010
    Hampshire
    Default Door Lock/Unlock buttons not working
    Hi everyone,
    I bought a 56 1.9cdti 150 about a month ago and love it to bits.
    Done a few upgrades already as suggested in the forums. Done the airbox mod and impressed by the improvement. Also fitted some rear parking sensors from Ebay for £16 which took 20 minutes to fit, again well impressed.
    But have had a few niggles with it and after reading through this forum have found every one to be quite common.
    1) Dash suddenly stopped working - SOLVED by removed F15 fuse by the glovebox
    2) Wobbly wing mirror - SOLVED by some "Sticks like s**t"
    3) Self removing gear knob - SOLVED with some more "Sticks like s**t"
    One thing that really annoys me though is having to unlock the car twice using the keyfob to unlock all the doors, but again found the valuable information on here to change it so that all doors open with one click.
    Unfortunately though it appears my Lock/Unlock door buttons on the drivers door don't work. All the other buttons work (windows and mirrors etc) and the lighting of the pannel works, but neither of the lock buttons work at all so am unable to change the central locking setting.
    Before I start pulling the door apart I thought I'd check here first to see if there was an easy fix.
    Thanks in advance
    Steve
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Pop the switch panel out and dismantle it, the just give the contacts a good clean. Its quite common mate, they just get a bit dirty. HTH
    Sep 2010
    Hampshire
    Thanks. Is it possible to pop out the panel without removing all the door panel?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Yes, just stick a small screwdriver or something down the end (careful you dont leave a mark on the door panel), it will just pop out.
    Sep 2010
    Hampshire
    Great, thanks for the advice, will give it a go this evening.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Just happen to have one of those switches sitting on my desk in front of me as my new one for my rear electric window conversion arrived this morning lol
    It's the silver clip on the left of this picture, there's one on each end.
    HTH
    Sep 2010
    Hampshire
    Just taken it apart, cleaned all contacts and still no joy, so I log on and see the above comment! Doh! Didn't check that contact. Will go take it out and try again. LOL.
    or is that just a clip??
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    No, that was just showing you the clips you had to free to pop it out of the door. You have to completely disassemble the entire switch and clean all the contacts under the rubber pads then re-assemble it. There's a howto on the site somewhere in the howto section.
    Edit: Here http://www.vectra-c.com/forum/showthread.php?t=92625
    Sep 2010
    Hampshire
    Brilliant. Thank you. I looked in the How 2 section but didnt spot that.
    I took the rubber bit off and gave the contacts a wipe the first time, didn't use sand paper though. Will try again with sand paper.
    WGAF#5
    DO NOT USE SANDPAPER - you will wear off the very fine contacts
    all you need to do is use a pencil rubber to give it a clean
  1. Door unlock order?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 19:24
  2. Drivers Door Lock not working
    By Rupster_69 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 16:07
  3. Door Lock/Unlock
    By Scoobydoobry in forum Bodywork & Interior
    Last Post: 15th February 2007, 19:22
  4. Door Won't Unlock
    By parapaul in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2006, 17:58
vectra c unlocks door
unlock vectra c doors
